A question about gear knob
Postby JMP » Tue 22.09.2015, 16:51
Hello there !
I wanted to share with you my last find on ebay : a NOS gear knob, being pointed out that those are no longer available at Lotus Cars, just as too many obsolete parts.
Here is the before/after sequence. We all know how to remove it, unbolting the knob anti-clockwise once the small screw at the bottom is made loose with an allen key:
I have one question about it :
The old one had the picture of the gears printed on the leather (almost impossible to read now).
The spare part I was lucky to find (for 48USD + shipment) has a different embossed feature, which should last longer.
Does someone know when it was introduced in the production ? Was it for the S2 ?
Lotus Seven s3
Lotus Elan M100 SE
Lotus Elise S1 PTP 165
JMP
Re: A question about gear knob
Postby JMP » Mon 28.09.2015, 03:30
More than 60 views and no answer to my question ?
Lotus Seven s3
Lotus Elan M100 SE
JMP
Postby Brit-Car-Nut » Mon 28.09.2015, 05:16
ALL of the following part numbers were superseded by A100F6062F:
A100F6050F
A100F6061F
A100V6062F
There is no history indicated as to when the changes occurred, but they probably went in that sequence.
Parts Guide V.2 shows part number A100F6062F with a designation of B3 for the model change.
Postby JMP » Tue 29.09.2015, 22:35
Thank you very much. :smt023
Lotus Seven s3
Lotus Elan M100 SE
JMP
