Steering wheel spline size...
Postby Jamie N » Tue 01.03.2016, 13:08
Appears to be pretty small, certainly in comparison with a Honda one, I'm wondering if anyone knows of another type of vehicle which has the same size spline?, I have looked at a few including some later model VX but all of them are larger.
Monaco S2 #406
Jamie N
Seal God
Re: Steering wheel spline size...
Postby Elanlover » Tue 01.03.2016, 13:47
Lotus Esprit.
An obvious candidate since they use the same steering wheel but I don't know if that will help you or not.
Postby DeanG » Wed 02.03.2016, 03:06
I thought the steering column and wheel were Pontiac.
DeanG
Postby donsladek » Wed 02.03.2016, 05:41
DeanG wrote:I thought the steering column and wheel were Pontiac.
The FED airbag wheel is the same design as the Pontiac Firebird/ Chevy Camaro, but the splined hole on the Pontiac/Chevy wheel is bigger.
I also read somewhere that the steering column came from the Isuzu parts bin...
Don Sladek
Calypso Red '91 #37594
donsladek
Postby dapinky » Wed 02.03.2016, 10:20
The part numbers for the FED (SIR) column is different to the UK spec ones, so beware that what fits a USA car may not fit a UK one (they might do, but I don't know if the splines are different).
I've never bothered to see what else will fit, as the boss is removable from the Lotus wheel, allowing you to attach whatever other wheel you want to it (within reason).
Postby cliff » Thu 03.03.2016, 12:17
Jamie,
Mitreklov mentions a Momo Boss Kit MK7903 in this thread. Listed as fitting Jag XJ-12. Isuzu Rodea & Vauxhall Frontera
viewtopic.php?f=108&t=24308&hilit=momo
http://www.b-gdirect.com/momo-hub-boss- ... k7903.html
Will be ordering one soon for my new wheel.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby Jamie N » Thu 03.03.2016, 21:08
cliff wrote:Jamie,
Thanks for the info Cliff, I'l have a look at a Frontera in the yard first, all I need is the boss section which I should be able to fabricate to fit a Nardi I have as long as the splines are the correct size, I could use the original one as Dave mentioned above but I would rather keep it all as one and use a donor boss if I can find one. :wink:
Monaco S2 #406
Jamie N
Seal God
