Door knob - small rectangular red plastic
Postby ebguitars » Fri 14.10.2016, 11:14
Hello, I have a quick question regarding the door knobs:
My Elan has both red rectangular plastic inserts located at the popping door handle at the window broken. Its not a big deal at all, but it simply looks bad.
My question is the following: in order to replace them, can I just simply pry them out and replace the red plastic with new pieces or is it much more complex and I need to disassemble the entire door panel?
Any help is welcome! Thanks, Ed
1992 (LHD) Pacific Blue Elan
ebguitars
Re: Door knob - small rectangular red plastic
Postby GeoffSmith » Fri 14.10.2016, 11:40
Postby TrevorB » Fri 14.10.2016, 15:40
also look at this which covers removal of door card
https://www.youtube.com/watch?v=sLJWCYD_lu8
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby lotusflasherman » Fri 14.10.2016, 18:05
I'm happy to live with a tiny hole in mine
and pull them out and re-use many times over using this ....
Ed, usually removal is first thing and replacement is last so all you have to do is get the old out and insert the new. Easiest way to remove the old is screw a small selftap screw in and pull the screw.
Postby ebguitars » Mon 17.10.2016, 09:59
Good morning and thanks for these tips. Lotusflasher, I think I will do just as you mentioned. I will buy a few spare ones and give it a try! Thanks
ebguitars
