GeoffSmith wrote:A bit of padded board that sits under the steering wheel to stop your knees twatting something hard in an accident.
lotusflasherman wrote:GeoffSmith wrote:A bit of padded board that sits under the steering wheel to stop your knees twatting something hard in an accident.
Is that part of the S2 and not on the SE? All I've ever had above my knees is a bit of plastic moulding that's an integral part of the facia panel..
Fredjohn wrote:lotusflasherman wrote:GeoffSmith wrote:A bit of padded board that sits under the steering wheel to stop your knees twatting something hard in an accident.
It was only ever fitted on federal cars Phil as far as I can tell.
lotusx180r wrote:I'll get it eventually. Next step is to see what size socket will go through the access hole and if it will go over the nut. I suspect the nut is 10mm like the other one and I don't think I have a socket that will do the job. I may have to buy or borrow a thin wall deep 10mm socket just for this job (buying a tool just for the job at hand is a thing with me)
lotusx180r wrote:This is the final fastener I need to undo in order to get the bolster off. I can't tell what is behind the hole, only that it is a fastener of some kind. The nut on the other side was a 10mm nyloc. The bolt is off center because all of the other fasteners have been undone and the bolster is hanging.
