On my car the 2 little lights under the inside mirror always light on
Maybey, it's the contact switch that has a problem, but where is it ?
Thanks you for your help and sorry for my english
type49 wrote:thank you for your answers. Ididn't know about this function on the light switch.
I'm nearly sure this switch isn't pulled out but i'll check that this week-end (not at home this week)
For the moment to turn this light off, i turn off the battery master switch
lotusflasherman wrote:type49 wrote:thank you for your answers. Ididn't know about this function on the light switch.
IN to OUT is a very small movement so might not be obvious when it's OUT
When I got mg first M100 about 15 years ago the same thing happened to me in the infamous Rambo but I hadn't, as then, joined LEC and benefitted from the experience and wisdom of some of our learned members so there was much head scratching on my behalf
Well bugger me I've had my car over 10 years and didn't know the switch did that Steve A wrote::bananasex: Well bugger me I've had my car over 10 years and didn't know the switch did thatcan't wait to give it a go
John_W wrote:Does your remote-control door locking work OK? Do the door lock buttons stay down? If not then the problem might be the microswitch in the doors (or the connections to it) which controls both the door lock and the lights in the mirror.
See this thread.
lotusflasherman wrote:One of the options for turning them on is to pull out the circular light switch selector ... are you sure yours isn't pulled out?
type49 wrote:lotusflasherman wrote:One of the options for turning them on is to pull out the circular light switch selector ... are you sure yours isn't pulled out?
Thank you for your idea, it was "the good one"
