Seat Repair/Re Trim
Seat Repair/Re Trim
Postby Wakeykd » Tue 04.06.2019, 12:06
Hi Guys, I am looking to have my seats repaired if they can. The foam is past its sell by date too as its just crumbling. I am based in Yorkshire and im wondering if anyone has used a company not too far from me before?
Wakeykd
Re: Seat Repair/Re Trim
Postby Jamie N » Tue 04.06.2019, 17:46
If you are not too concerned about originality why not spend the money on a pair of Honda S2000 seats, you will probably pay the same amount of
money but end up with something aesthetically and ergonomically superior . This is a pair on Ebay... https://www.ebay.co.uk/itm/HONDA-S2000- ... SwWtpcbBYV (not mine), they also come in red and black leather.
A very nice upgrade, but there are a few others which will also fit in the Elan with a bit of modifying. :wink:
Monaco S2 #406
Jamie N
Seal God
Postby LRS7 » Tue 04.06.2019, 22:28
Hi Kris
I’ve used a company called Seat Surgeons in Strensall, North Yorkshire who did a great job on one of my Range Rovers .. The guy who owns it name is Paul try them they are close ish to you. Failing that I’ve got a guy in Ilkeston who can do it.
I’ve also got a set of cloth/leather seats with matching inserts if you fancy them instead? I was going to put them in my SE but decided against it so going spare.
Range Rover Vogue
Range Rover Evoque
Lotus Exige S2
Suzuki Bandit
LRS7
Postby wayne » Wed 05.06.2019, 01:02
If you want to keep the OEM seats. I have a company here that can remake the covers, but your looking at about £500 ish.
http://www.elanm100.com
wayne
Postby Wakeykd » Tue 06.08.2019, 17:28
Slight update. I ve the car booked in with a chap in Wakefield. We used to use his company at work 15 years ago called Vasco. He retired but found out from my dad who takes his TR6 for Mot to a place in wakey he’s still doing it part time. Got it booked in October. He said he can repair what’s already there which is good as I wanted to keep the original seats, the foam will need replacing as that’s disintegrated and he’s only charging £60. I will update with pictures after. Are the seats pretty straight forward to take out?
Wakeykd
Postby Saltire » Tue 06.08.2019, 20:57
Wakeykd wrote:Are the seats pretty straight forward to take out?
Four bolts on each seat, plus (on the drivers side) the seat belt warning lamp wiring on the inside behind the seat (against the “transmission tunnel”). Note that there are normally spacer washers under the seat; one (inside rear IIRC) is thicker than the other three. Some folks remove them to give a little more headroom.
And while you have the seats out, it’s a great chance to check the inner sills for rust, throw away the old spongy under felt and replace it with some decent Non-absorbent under felt and/or Dynamat
Postby Wakeykd » Tue 06.08.2019, 21:43
Thank you for the advice, I didn’t know about the seat belt warning light!
Wakeykd
Postby Blue ass fly » Tue 03.09.2019, 18:44
LRS7 wrote:Hi Kris
Any pics of your spare seats ( if theyre still available)
Blue ass fly
Postby GROMIT007 » Mon 30.09.2019, 15:54
Any one know of a re trimmer in the south . I have my original gray with the red strip seats that needs fully re doing .As you can see from the picture . I think sending them north will cost to much .One of the many jobs to be done over the winter ,And new roof :cry:
If you do please let me know.
Gromit
GROMIT007
Postby Rambo » Mon 30.09.2019, 18:28
OMG, what a mess. And cloth door cards too. Has your car sat out in the rain for months with the roof down :shock:
If you search on here, Tuga got his mate to do a good job on his seats. Not in leather but a good substitute and significantly cheaper. I saw them at CC and the quality of workmanship was excellent
GROMIT007 wrote:Any one know of a re trimmer in the south . I have my original gray with the red strip seats that needs fully re doing
South of where anyway. If you put your location in your profile it makes it easier for a fellow LEC'r to help out or recommend a garage. Or seat repairer 8)
PS with your car in such a poor state inside I would suggest removing the carpets and underlying foam immediately. Without wishing to sound alarmist, I suspect you will find you have more serious and expensive outrigger/sill problems
Postby rip » Mon 30.09.2019, 23:47
Neil's auto interiors near Southend, Essex. They do a lot of custom cars like hot rods & had no problem with my Elan. They replaced several of the base clips & some of the foam which was in a poor condition.
They also fitted seat heaters (which I wired in). These are fantastic when it is cool but not cold. I recommend fitting some while you have a chance.
They also had a good selection of different coloured leather.
Postby GROMIT007 » Tue 01.10.2019, 12:22
Thanks Guys for the info.
Yes the inside looks in a bit of a mess ,but every thing still works .The car is getting a full strip down . And respray .ive owned it for 14years so I think I owe at least that . so will see any damage when they start that . believe it or not its it past its MOT 2 months ago .And had a full service . Im looking forword to getting it back on the road in the spring . I hope .
Gromit
GROMIT007
Postby GROMIT007 » Tue 01.10.2019, 12:24
Sorry forgot im in Camberley :D surrey
GROMIT007
Postby Rambo » Tue 01.10.2019, 20:20
Gromit - here's the thread I was on about re. Tuga's replacement seat covers. Unfortunatelty the photos seem to have disappeared :?
viewtopic.php?f=80&t=23694&start=340
Postby uk08462 » Sat 28.12.2019, 19:59
rip wrote:They also fitted seat heaters (which I wired in). These are fantastic when it is cool but not cold. I recommend fitting some while you have a chance.
My seats need new bases and this is a mod I'd also like to do at the same time. Any tips on type of heated seat and what is involved in the wiring?
S2 #048 BRG
uk08462
Postby baldyash » Sat 28.12.2019, 20:32
Also had my seats retrimmed by Neil's. A great job. If you go there have look at whatever hot rods are there.Amazing work.
baldyash
Postby MarkP » Sat 28.12.2019, 20:54
I just used AJTrimming in Bourne End (near Maidenhead) to repair a split in my drivers seat. Did a good job. He had to make up a new panel as the split one was not repairable and then added some extra padding.
MarkP
Postby lotusles » Sat 28.12.2019, 20:59
GROMIT007 wrote:Any one know of a re trimmer in the south . I have my original gray with the red strip seats that needs fully re doing .As you can see from the picture . I think sending them north will cost to much .One of the many jobs to be done over the winter ,And new roof :cry:
Gromit
Dave King
31 Le Marchant Road
GU16 8RN Camberley
lotusles
Postby rip » Mon 30.12.2019, 13:22
I got mine from Ebay. I think I paid £50 for both seats in 1 pack. This looks about the closest, but is considerably caheaper & only for 1 seat. The switch looks the same as what I have.
It was quite a few years since I wired mine in, but I used 3 fuses: 1 for each seat & a main one for the pair together. In theory, one of the first 2 should trip if anything goes wrong.
I also took a feed from the ignition (possibly from one of the window switches, but I can't quite remember that bit). This feed was for a relay so the heaters cannot flatten the battery.
The battery is in a very nice location for this. I ran a feed from the battery to the main fuse & relay then to the switches/fuses for each heater.
The kit (or in this case kits) provided connectors so the seats & heaters can be removed. The connectors for the seats being underneath & the switches under the centre console storage tray. The only snag about having the conenctors for the switches here is that the switches themselves are on the centre console in a location which can (& sometimes do) get knocked by my elbow...so I occasionally end up with a warm bum when I don't expect it. :poke:
Postby uk08462 » Fri 03.01.2020, 12:14
Thanks for the tips!
S2 #048 BRG
uk08462
