Door Lock Pins & Escutcheons
Postby CallMeLegend » Sat 20.06.2020, 18:47
Looking for door lock pins & escutcheons for both doors if anybody hes some lying around?
CallMeLegend
Re: Door Lock Pins & Escutcheons
Postby Rambo » Sat 20.06.2020, 19:25
Do you mean the door check strap pins (A100B6020F) If so, SJS.
They also stock door escutcheons https://www.sjsportscars.com/
Postby CallMeLegend » Sat 20.06.2020, 19:55
Rambo wrote:Do you mean the door check strap pins (A100B6020F) If so, SJS.
No, the actual plastic pin, the bit with the red plastic peice
CallMeLegend
Postby Rambo » Sat 20.06.2020, 20:05
Available from SJS too
Postby Brit-Car-Nut » Sat 20.06.2020, 20:36
Do you mean this?
#14 - A100B0089F
#15 - A100B6151H
It would be easier if you download the parts manual and look up all the parts you are asking for.
http://www.lotusm100.com/manuals and then click on "Elan-M100-Parts-Guide-v8-(S2).pdf" and save it to your computer.
Once you have the part number, you can open http://www.Deroure.com and search the number (upper right hand corner) to see if it is still available from Lotus
or go to https://www.sjsportscars.com and see if they have any stock there.
Postby Graaf » Sun 21.06.2020, 19:59
The lock buttons and escutcheons were used on the Vauxhall’s Carlton.
Graaf
Postby CallMeLegend » Sun 21.06.2020, 20:20
Graaf wrote:The lock buttons and escutcheons were used on the Vauxhall’s Carlton.
Thanks. I can to the same conclusion. Remembered they looked familiar, my dad had a Carlton.
Found. Few in scrappers online.....now to wait for a response from them.
CallMeLegend
Postby GeoffSmith » Sun 21.06.2020, 21:47
Also Holden Commodore if you've got contacts in Australia.
Postby CallMeLegend » Mon 22.06.2020, 16:47
Bugger me with a fish fork.
https://www.tseptin.com/lotus-elan-m100 ... 07372.html
Anybody want some since I'm putting an order in?
CallMeLegend
Postby GeoffSmith » Mon 22.06.2020, 17:03
Call me a cynical old bastard (or just old bastard if you're a friend) but… they don't give a physical address, seem to sell virtually everything under the sun yet only registered the domain name a month ago.
https://who.is/whois/tseptin.com
Postby CallMeLegend » Mon 22.06.2020, 17:21
GeoffSmith wrote:Call me a cynical old bastard (or just old bastard if you're a friend) but… they don't give a physical address, seem to sell virtually everything under the sun yet only registered the domain name a month ago.
I'll contact them & see what transpires.
CallMeLegend
Postby NewLogik » Fri 26.06.2020, 00:13
Did you had the chance to contact them ?
NewLogik
Postby CallMeLegend » Sat 31.08.2024, 08:25
CallMeLegend wrote:Looking for door lock pins & escutcheons for both doors if anybody hes some lying around?
I have these available once again, good quality repro parts.
https://www.ebay.co.uk/itm/256622410327
CallMeLegend
