Door trim panel install
Postby jello » Thu 04.03.2021, 18:22
Door Cards. I had my door cards rebuilt and reupholstered. They were glued in with some unknown glue like gorilla glue.
I want to put the new door cards in, but don't know how the factory mounted them.
Any recommendations? I want them fairly easy to remove, as the car will be painted soon.
Phil Bates
jello
Re: Door trim panel install
Postby Simon_P » Fri 05.03.2021, 13:51
In the repairs section above there is a window regulator article. The article refers to Charlies fix - follow the link.
Postby HJ2 » Fri 05.03.2021, 15:39
... don't tell us that the piece of carpet is already glued in position, covering the holes!
Postby jello » Fri 05.03.2021, 17:45
Thanks for the link. It's been a while since I was actively working on the interior of this car. Now I remember the link, the job, etc, etc. I do have a window that needs work - maybe I'll take off the door panel and fix that lift mechanism before putting the panel back in.
This will sound odd, but the way I used to have the door cards was installed with velcro. I think I'll do that again. That way they are easily removable, but they are securely affixed.
jello
