Ash Tray housing removal help needed
Postby oneills » Tue 23.11.2021, 20:13
Hello All
Would anyone know if there is a knack to removing the ash tray housing without breaking it.
I cant see anything in the manual
I could try and prize it out but I am afraid it may crack but if that is the way then I will have to be careful
Thanks in advance
Shaun
oneills
Re: Ash Tray housing removal help needed
Postby dapinky » Tue 23.11.2021, 21:29
Hi Shaun,
I removed mine many years ago to fit a satnav unit in the space.
It is "just" glued to the rear of the fascia panel - but the glue was pretty solid. I wasn't keeping mine, so the fact that it cracked and broke wasn't a great worry to me - but I didn't want to damage the fascia, so took some care.
I ended up cutting it and getting a slim chisel between the lip on the housing and the fascia, then gently easing the two apart.
Without damaging the housing, I would suggest that the best way would be to undo the fascia fixings and then get a suitable tool behind and ease the two parts away from each other. Once it starts to separate, it is very simple to complete the job.
Postby muley » Wed 24.11.2021, 00:05
Somewhere in LEC, there's a note about this. I've tried to find it
IIRC it involved heating the tray with a hair dryer to soften the gunk that holds it in.
HTH
Postby oneills » Wed 24.11.2021, 12:53
Thanks Guys - that is very helpful
It has been out before are a cable has been fed through it ?
I'll contact the previous owner to see what he did
Shaun
oneills
