seat installation
seat installation
Postby M100TURBOFR » Sun 23.10.2022, 12:05
Hi.Clarification required please. Seats been out for a while and can't remember exactly. There are 4 bolts two of which are longer. Do the longer ones go at the rear and is the bigger spacer (29mm) installed at rear next to the seat belt achorage side i.e. next to the door?
Thanks again. David
M100TURBOFR
Re: seat installation
Postby Fredjohn » Sun 23.10.2022, 14:31
See page 13.01A of the parts catalogue for guidance.
Postby dapinky » Sun 23.10.2022, 14:51
Basically, the inner 2 bolts are captive, so use the short ones (the long ones will hit the bottom of the captive cage before they are tightened and the seat will remain lose. The outer 2 have washers and nuts on them, fitted from underneath (there is just about enough room for an average person to both hold a spanner on one end and a ratchet on the other).
The slightly longer spacer goes in the rear outer position.
Postby M100TURBOFR » Sun 23.10.2022, 16:00
Thanks. As always help is at hand.
M100TURBOFR
