Gaiters
Gaiters
Postby LeedsMike » Fri 18.11.2022, 15:47
Looking to get new gaiters for my S2 for both handbrake and gear.
It looks like most suppliers offering the package with the yellow stitching (the style I’m looking for) are only for SE models.
Couple of questions:
Saw in a previous post the SE and S2 fittings are different- does the difference make the SE ones hard or impossible to fit to S2? Is the fit poor, acceptable or good?
Does anyone know of a supplier who makes the ones I am after for the S2 sizing?
Thanks!
S2 #388
LeedsMike
Re: Gaiters
Postby Graaf » Fri 18.11.2022, 18:26
Allon White Sportscars will make them up.
Graaf
Re: Gaiters
Postby Saltire » Fri 18.11.2022, 18:30
Any decent trimmer would make up a set to match your existing; it’s not a hard shape in either case. Make sure they remember to put the strengthening wires in the gear gaiter, and I had a small section of elastic stitched round the top of mine so it stays on the gear knob.
As I recall, the worst part of the job is persuading the old handbrake gaiter to detach from the centre console - it uses those horrible spring tine clips and it’s all too easy to cut your fingers to ribbons.
Re: Gaiters
Postby Tuga2112 » Fri 18.11.2022, 19:55
Saltire wrote:Any decent trimmer would make up a set to match your existing; it’s not a hard shape in either case. Make sure they remember to put the strengthening wires in the gear gaiter, and I had a small section of elastic stitched round the top of mine so it stays on the gear knob.
the most annoying part about it for me is the fact that removing the centre concole to do the job in the workbench doesnt make the task any easier because re-installing it without the gaiter is 100 times easier than without one.
Re: Gaiters
Postby Saltire » Fri 18.11.2022, 20:29
On the S2 (which is what the OP was talking about), it makes little difference, Joao, because the centre console design changed :-D
Re: Gaiters
Postby Rambo » Fri 18.11.2022, 23:09
:lol:
PS not as neat as the SE though :poke: You bump your left elbow when downshifting :lol:
Re: Gaiters
Postby Tuga2112 » Fri 18.11.2022, 23:31
i keep forgetting the S2 actually has SOME differences that are not the alloys.
Re: Gaiters
Postby Saltire » Sat 19.11.2022, 09:01
Rambo wrote::lol:
But I use my battery connector under the bonnet all the time, Mark :D
What’s that? You haven’t got one??? :twisted: :lol: :lol: :lol:
