by pietro » Sat 07.12.2024, 18:37
good evening
i mounted the steering wheel hub for momo
there is the hub code for those who want to buy it
it is good for the elan.
only the horn did not work well,
i mounted a spring on the horn pin and solved it
to disassemble it i gave it the wd 40, to unlock
if anyone needs the hub code it is correct
i hope it is understandable i translate with google
in the desert only the Bedouins and the Gods feel at ease.
And you, Lawrence, are none of these
