replacement rubber seals around door and screen
Postby browfish » Mon 12.12.2005, 16:38
Anyone know if it is possible to get hold of the rubber foam seals that go around the outside of the windscreen between the doors and roof. Some of these have split and the foam absorbs water and can leak in places.
If so are these easy to fit?
thanks
james
browfish
Postby Gary » Mon 12.12.2005, 17:03
Hi James,
I'm sure some-one else will confirm this, I'm pretty sure you can get them, but I think they are IRO £150 per side ?
Postby ailwyn » Mon 12.12.2005, 19:35
I have exactly the same problem.
Spoke to Paul Matty's last week only to be told that there are no supplies and Lotus are trying to source another manufacturer.
My enquiries haven't gone beyond that, mainly because I can't get PM to sell me a hard top to go with them! :o
Are there many people here who need new seals? Perhaps if we can get enough people then Lotus might pull their finger out??
Ailwyn
Postby Candles » Mon 12.12.2005, 20:10
I need them but I wouldn't pay anywhere near that amount for them. Perhapy £30 per side??
Candles.
Candles
Postby theelanman » Tue 13.12.2005, 01:32
have you guys tried talking to trim tech?.....
they were the original manufacturer of the hoods and are currently making new ones with all the seals.....I've just had a new hood fitted with new frame and seals and the seals that were on my old hood which trim tech took were still good....so they should at least have some very good second hand seals!!!!
cheers
G
Postby Sy V » Tue 13.12.2005, 09:24
Agreed.
Dean Holt
Sales Manager
Trim Technology & Services Ltd
Tel: 02476 646000
Postby ailwyn » Tue 13.12.2005, 13:11
Are we talking at cross purposes or do Trim Technology change the seals that run up the sides of the windscreen (A-posts?) between the windscreen and the front part of the door window?
I thought it was only the seals that are physically attached to the hood?
Ailwyn
Re: replacement rubber seals around door and screen
Postby theelanman » Tue 13.12.2005, 14:01
browfish wrote:between the doors and roof. Some of these have split and the foam absorbs water and can leak in places.
thanks
james
can we have clarification please......
'a' post seals or hood seals?......between doors and roof means round the hood to me...between the doors and windscreen mean 'a' post seals......
mine were a bit past it too but I used the black goo from halfords to reseal them........at halfords its now a loctite product..40ml tube....£4 a go
called loctite superflex black (think they did a clear one too!!)
halfords cat number 24802
this works like normal sealant and is very good stuff....and its also easy to get off if you make a mess of it
hope this helps
chers
G
Postby Monty » Tue 13.12.2005, 17:39
Brow fish said between door and roof so would think it`s the intermedate or maybe even the front hood seal which goes part way round were the door class is.
IIRC SJ`s do the front hood seal at £145 and the intermediate for about £30 :?
But i`d try Trim tech 1st
Postby timmo » Thu 15.12.2005, 01:10
TT dont do them, trust me.
I wonder how much deeper the ocean would be without sponges.
timmo
Postby theelanman » Thu 15.12.2005, 01:28
does that mean that this discussion is about a pillar seals then!!!!
as trim tech advertise the seals for the rest of the hood!!!!
Postby timmo » Thu 15.12.2005, 01:32
as far as my bit goes, yes they dont fo the a pillar seals. I know this as they did a roof for me 4 weeks ago and we talked about them at length.
timmo
Postby theelanman » Thu 15.12.2005, 01:44
quite true.....
if its the a pillar seals people want then I think a letter to santa for them or contributions towards them might be an idea then!!!!
cheers
G
Postby browfish » Thu 15.12.2005, 10:25
Sorry, just to clarify what i meant. Reading it back i didnt explain it very well.
The bit that i am after is the bit that runs down the side of the windscreen and seals to the door windows. The previous owner had sealed them with black goo. However wher the original seals are split they absorb water like a sponge and the goo looks unsightly. i want to replace with new seals if possible.
cheers for all the help so far
browfish
Postby Sy V » Thu 15.12.2005, 10:47
OK.
These are A pillar/post seals and can be bought separately from most of the usual outlets.
Body & Trim | Body Seals
L/H 'A' POST SEAL B100V0117F EACH 121.54
R/H 'A' POST SEAL B100V0118F EACH 121.54
These are (without VAT) quotes from SJ Sportscars.
http://www.sjsportscars.co.uk/partsanda ... /parts.asp
Postby Gazza » Thu 15.12.2005, 11:31
When I had my A pillar seals replaced on my first Elan, I replaced the runners they sit in as well, at about £30 a side.
Just seemed cheaper and quicker than trying to remove the glue from the old ones. So with parts and fitting cost me nearly £500 and it still was not much better :cry:
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby browfish » Thu 15.12.2005, 16:26
OUCH!
Maybe i will be sitcking with the ones ive got then.
Nevermind, thanks everyone.
browfish
Postby theelanman » Thu 15.12.2005, 17:50
hope this helps
chers
G[/quote]
I did mine this way....its all about how steady you are with the tube!!!! have a practise first......dont forget that you can create this away from the car and then use the same sealant to stick it on.....its possible to do these in different ways but what you end up with once its cured is plyable rubber!!!
buy a tube and play!!!!
like playdo fo adults!!!!!!
lol
G
Postby Sy V » Fri 16.12.2005, 09:17
...but wear some disposable rubber/latex gloves - it sticks like s**t to a blanket.
New roof
Postby Ravij » Wed 25.01.2006, 10:44
Just curious but how much dod they charge for a new roof?
timmo wrote:as far as my bit goes, yes they dont fo the a pillar seals. I know this as they did a roof for me 4 weeks ago and we talked about them at length.
Ravij
