by Low Profile » Tue 17.01.2006, 21:39
Can someone tell me where the switches in the doors that operate the courtesy light are please? and also if they are supposed to time of where is the timer?
PS: - Do not check out my profile because it says Electrical Engineer and due to this question it’s obviously not true!
FOREVER SEARCHING FOR YOUTH!
Low Profile
by Sy V » Wed 18.01.2006, 09:19
If yours are staying on, make sure the headlights switch is pushed in towards the dash. There's a timer module for the lights to go out...I'll check where later and get back to you.
- LEC Godfather
by discovery6 » Wed 18.01.2006, 09:36
Think i have same problem. Bleeding brakes at the weekend to try and make them work ! When it came to putting car in garage int lamps would not go off . Had to pull the fuse and hopefully sort out this weekend so any info would be helpful.
p.s. brakes still crap.
discovery6
by Sy V » Wed 18.01.2006, 09:40
Bleed...bleed and rebleed! leave a week and run car, then bleed again.
Don't push pedal to the floor.
- LEC Godfather
by Low Profile » Wed 18.01.2006, 11:40
Thankyou Sy V, I'll check it when I get home! Lp
Low Profile
by Sy V » Wed 18.01.2006, 18:38
Here's the wiring diagram:
Here's the plan of the modules which are under the dash in the driver's foot well:
- LEC Godfather
by Low Profile » Wed 18.01.2006, 21:18
Thank you very much for taking the time to sort out out these drawing! Got home tonight and found the switch on the main lights you were taking about, put the lamps back in the curtesy light turn them off and SORTED! Thanks again Sy V. Hope I can repay the favour one day!
Low Profile
by Sy V » Thu 19.01.2006, 09:53
...it just so happens that I might need some guidance from an AVO/Multimeter operative (see my Hill Climb Elan thread in Projects).
- LEC Godfather
by Low Profile » Sat 21.01.2006, 22:50
At your service!
Low Profile
by Sy V » Sun 22.01.2006, 08:13
Noted - thanks.
I'll be in touch if necessary!
- LEC Godfather
