rheostat - as if
rheostat - as if
Postby brubaker » Sun 30.07.2006, 16:16
So I've now noticed that the rheostat knob doesn't affect the brightness of the LED lights - no matter which way you turn it - they stay the same.
Noticed on another thread that there are a few things it could be - any advice guys...
I also have to replace one of the led bulbs - one has clearly blown - where do you get such things?
PJ
brubaker
Postby Candles » Sun 30.07.2006, 19:58
LED lights? I'm not sure mine has any.....?
Candles
Postby John_W » Sun 30.07.2006, 21:18
There are no LEDs on mine. If there were, a standard rheostat wouldn't be able to control them.
Could you give more details?
Postby GeoffSmith » Sun 30.07.2006, 21:22
If you have got LEDs then the rheostat will probably not make the blindest bit of difference. It is designed to work with standard incandescent lamps which are a lot lower resistance. As Candles says, LEDs are not standard even for the S2.
Geoff
Postby brubaker » Sun 30.07.2006, 21:40
my mistake guys i guess i meant incandescent lamps - just didn't know what to call them!
Thoughts?
brubaker
