Starter Repair Kit
Starter Repair Kit
Postby Simon_P » Thu 21.11.2019, 01:54
Hi All,
As promised the Starter Repair Kit list is here. I have the BOM and can get most of the parts. It is a few years since I rebuilt one and it is the terminals and plunger that wear out. There is also a cover gasket that I intend to include and a rubber terminal boot on the side that is prone to perish or get eaten by mice, which I suggest is optional as it is six quid.
I will take pictures of the parts when they arrive.
Re: Starter Repair Kit
Postby GeoffSmith » Thu 21.11.2019, 08:29
:clap:
Postby woody » Thu 21.11.2019, 09:53
To get things started a list!
1. Woody
2.
3.
4.
5.
6.
7.
8.
9.
10.
woody
Postby dapinky » Thu 21.11.2019, 11:14
1. Woody
2. Pinky
3.
4.
5.
6.
7.
8.
9.
10.
Postby Tuga2112 » Thu 21.11.2019, 12:45
Simon,
im interested, do you have an estimate of price ?
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby M100TURBOFR » Thu 21.11.2019, 14:08
Simon Hi
Can you confirm for which Starter motor the proposed kit is intended. (Denso, Lotus, other....)
Other parts required may well include the two (2) roller bearings (depending on play).
M100TURBOFR
Postby M100TURBOFR » Thu 21.11.2019, 15:29
Simon asked me to post the following info. It may be of help to those envisaging the repair of the starter motor.
My one packed up two weeks ago (I added a post requesting info on removal). In the meantime, I eventually managed to get it out and have had it refurbished.
Removal is far from being easy, especially the top bolt located underneath the plenum making access very difficult. It's impossible to access from beneath so go in from the top (engine compartment). I found removing the gearshift cable bracket and pushing cables aside made it easier to access. There's no room for a socket so the ideal tool is a "C"-shaped or "S"-shaped 14 mm spanner and even with this brute force and perseverance are required.
As Simon stated, the most common cause of failure is the plunger unit and the copper contacts. The latter were extremely worn (scored). My brush set was ok but I also required the two roller bearings as there was slight play. I'll also need a new "boot" which was unavailable.
Have attached a few photos.
M100TURBOFR
Postby Saltire » Thu 21.11.2019, 15:55
dapinky wrote:1. Woody
2. Pinky
3. Saltire (Jonathan), inc. rubber boot please
4.
5.
6.
7.
8.
9.
10.
1995 Elan S2 no 512, BRG/magnolia, last of 4 UK S2 to this spec - SORN
2020 Volvo XC40 T4 AWD
Postby Simon_P » Thu 21.11.2019, 16:29
M100TURBOFR wrote:Can you confirm for which Starter motor the proposed kit is intended. (Denso, Lotus, other....)
8944410871 is the Isuzu number 128000-4571 is the Denso number A100E6028S is the Lotus number they are one and the same made by Denso.
I can do the bearings but that adds to the cost, they are C3 tolerance which has more play than usual I'll do a rebuild and make suggestions.
Tuga2112 wrote:im interested, do you have an estimate of price ?
It depends on what is included I'd rather have parts and pictures before saying more.
Postby Simon_P » Thu 21.11.2019, 16:46
2. Pinky
4.
5.
Typical LEC anything for a list! and this one has started without me and I'm not sure what the options are.
See the wiki for rebuild details. The Plunger and the terminals are clear, looking at the second picture you can see a gasket shaped like a house and the terminal boot on the end of the blue cable cover. Are we talking about the same boot? there is also the one on the end of the harness cable which I will have to find if that is required as well.
Postby Saltire » Thu 21.11.2019, 20:05
Sorry Simon, I hadn’t noticed it wasn’t you who started the List. Happy to wait for you to sort out what’s needed, but still expressing interest.
The boot I meant is the one to which you referred in your original post, but please let us know the final shape of the kit and I’m in.
And thanks for doing another Group Buy; much appreciated.
Postby Rice crispy » Sat 23.11.2019, 17:36
2. Pinky
3.ricecrispy
4.
5.
6.
7.
8.
9.
10.
Rice crispy
Postby Simon_P » Fri 06.12.2019, 15:57
Sorry for the delay - Slight cock-up on the ordering front and then flu.
here are the pictures of the parts
I will rebuild a starter over the weekend and then propose a kit
Postby woody » Fri 06.12.2019, 18:10
Simon,
I cannot see any pictures !
woody
Postby Simon_P » Fri 06.12.2019, 21:33
Sorry - Cock-up on the picture resizing front
Postby Simon_P » Thu 19.12.2019, 13:36
Ok I've taken the starter to pieces and looked at various parts. My starter wasn't too bad just worn terminals but David's needed the motor bearings replaced. So I suggest 2 kits Kit = A Plunger, Contacts, boot and seal as picture.
and Kit B - As above plus the motor bearings.
Prices:
Kit A will be £12 plus postage
Kit B will be £23 plus postage
Postage is 20p for the envelope and about £4 with Royal Mail I'm looking at cheaper options. so it may be a little cheaper if you aren't in a hurry.
The reduction gearing is available so I'll post more after the rebuild (Hopefully tonight) and maybe a kit C. Also if you would like other parts eg brushes please make a note.
Please add your name to the appropriate list
Kit A
1.
2.
3.
4.
5.
Kit B
1.
2.
3.
4.
5.
If people can get names added quickly I can probably get a few out as stocking fillers in the post tomorrow. It's good when your hobby is useful for things like that :wink:
Postby Tuga2112 » Thu 19.12.2019, 18:55
Hi Simon,
Id like 2 B kits. but im currently suffering from a small financial hiccup, any chanse to reserve/keep them on the side and complete transaction at the end of january ?
1991 elan se
94 4Runner
98 Celica SR
Postby Simon_P » Thu 19.12.2019, 19:14
Hi Tuga,
It's that time of year - End of Jan is fine with me Please add your name to the list with a note "end of Jan"
I have bought a few kits in advance if any of the alternator kit people want one (to save £4 on postage) or if anyone is desperate, or needs a Christmas present.
Postby Tuga2112 » Thu 19.12.2019, 19:22
Kit A
1.
2.
3.
4.
5.
Kit B
1. Tuga2112 - 2x "B" Kits. (end of Jan)
2.
3.
4.
5.
1991 elan se
94 4Runner
98 Celica SR
Postby dapinky » Thu 19.12.2019, 19:56
Kit A
1.
2.
3.
4.
5.
Kit B
1 & 2. Tuga2112 - 2x "B" Kits. (end of Jan)
3. Pinky (no rush at all, but can pay whenever you want it).... Oh, and can I have brushes as well please :D
4.
5.
Return to Elan Products For Sale (new and used products either custom made or upgraded versions of stock items)
