Brake Pads To Fit Rear PNM Calipers?
Moderators: theelanman, muley, Enright, algirdas, nitroman, clemo, dapinky, Nige, Dave Eds, Sy V, DaveT, Specky, Elanlover, GeoffSmith
Postby par » Tue 03.01.2017, 20:59
Would be grateful if someone could advise on the correct type of brake pads to suit the 16" rear PNM conversion.
Going by the search results it seems the calipers are based on those fitted to the Golf MkIV, does that mean any pads for a Golf MkIV are suitable for the kit on the Elan and does the 15" & 16" kit use the same pads? The PNM website seems to list different part numbers for the pads in each of the kits.
par
Re: Brake Pads To Fit Rear PNM Calipers?
Postby GeoffSmith » Tue 03.01.2017, 21:20
PNM fettle the Golf pads to suit the 15" and 16" setups.
USB ElanScan interfaces - Sorry, currently unavailable.
Postby par » Tue 03.01.2017, 23:21
Thanks Geoff, probably easiest just to buy direct from PNM then.
par
Postby Jamie N » Tue 03.01.2017, 23:46
par wrote:Thanks Geoff, probably easiest just to buy direct from PNM then.
Probably easiest doing to them what PNM do.... Grinder :D .
Jamie N
Seal Wrangler
Postby par » Wed 04.01.2017, 00:40
Jamie N wrote:Probably easiest doing to them what PNM do.... Grinder :D .
Not a bad shout Jamie as I can use the old ones as patterns! Just ordered a set for £9 so not expensive if I make a mess of it.
par
Postby Scott J » Mon 09.01.2017, 19:54
Pads were almost new so you've been racking up the miles :D
PNM sell them as mentioned .
Scott J
Hairdresser
Postby par » Mon 09.01.2017, 20:32
Not as many miles as I would have liked :D
I have new discs to be fitted as the current ones are quite pitted (probably from sitting around at SMS) and would rather fit new pads. I picked up a set of the Golf MKIV rear pads for under £10 with the Eurocarparts discount and cant see any difference, so maybe it is the 15" kit that the pads get fettled for!
par
Postby John_W » Mon 09.01.2017, 21:56
par wrote: so maybe it is the 15" kit that the pads get fettled for!
Yup. :smt045 :smt023
Philistine
