F1 LOTUS wrote:2.10" may be a typo - check the Dimension D1 calculation [left side of table] - it uses 2.03, same as Dynalite![]()
Best to call them and ask?
bobbrown wrote:My reason for selecting the Dynapro radial mount was it had dust seals. The lug mount version does not have dust seals. Bob
F1 LOTUS wrote:... the latest info' shows the Dynapro being narrower than the Dynalite? - Proceed with extreme caution...
. Also means right now, only Wilwood makes pads. So I'm going back through old forums to decide between Polymatrix Q, smartpad 10 and smartpad 20. I need something that'll play nice with the greenstuff on the back.tigerdog wrote:Also means right now, only Wilwood makes pads
bobbrown wrote:I think you will find EBC also make pads for the Dynapro, DP2039 green stuff DP4039 yellow stuff and and Dynalite calipers DP2038 green stuff DP4038 yellow stuff. http://www.summitracing.com/parts/EBC-D ... refilter=1 As do Mintex, Dynapro MDB2581/M1144 Bob
.Or a 1.5" - IIR, BobB says that would be the ideal match. Anyway, I received the new calipers before I shipped out the old ones, so I could do a side by side comparison. Placing them back to back on a tabletop, if anything the Dynapro lug mounts appear marginally (< 1mm) shorter than the Billet Dynalites. As you can see in the photos, they're definitely narrower. They also appear to have a little nicer finish - more machine work. You'll also note the different pad retention mechanism. Instead of a single cotter pin, these have a multiple-bend clip. The clip threads through the pad, so there's no need for the pad retention fingers at the bottom.nitroman wrote:Good catch. A shame they don't make the Dynapro with a 1.62" piston! The pedal is really firm with a short travel, totally unlike the 120-6816.
