Track rod ends
Re: Track rod ends
Postby GeoffSmith » Sun 22.02.2009, 00:37
And even when you've had to buy a brand new Lotus one at some astronomic price, it doesn't mean the old one is going to come off easy!
I eventually resorted to grinding it down and cutting into the threads on one side with a Dremel. :censored:
Re: Track rod ends
Postby RayD » Sun 22.02.2009, 09:30
Good work Geoff,
There’s a lot to be said for using Copperslip.
Looking at the amount of contact on the taper it might be a good idea to make the old one into a grinding in tool - using a bit of fine paste you should be able to improve the fit.
As you’ll know... Be sure to clean all the grinding paste off and use a felt tip pen to check the contact on the new one.
Re: Track rod ends
Postby Gordon » Sun 22.02.2009, 15:29
Just trying to get the bottom line of all this; are we saying that ALL the crossreferences or Wikilec are currently wrong? - or at best, unadvisable?
Gordon.
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Re: Track rod ends
Postby Specky » Sun 22.02.2009, 15:39
Gordon wrote:Just trying to get the bottom line of all this; are we saying that ALL the crossreferences or Wikilec are currently wrong? - or at best, unadvisable?
Gordon.
There's only one way to get the correct items that I know of....
LotusAftersales... S2 Steering rack for just over a 100 odd quid... bit of bargin even if it's just for a few bits off the rack
Re: Track rod ends
Postby Readit » Tue 24.02.2009, 22:10
All alternative suppliers seem to have been exhausted.
I believe SJ Sportscars can provide a replacement Lotus part at about £66 plus VAT but I have not checked their website lately.
These are vital replacement parts if an MOT pass is required.
All the best plans are flexible, Lotus use Sicaflex.
Readit
Re: Track rod ends
Postby RayD » Wed 25.02.2009, 10:05
I’ll have another word with QH and ask again about modifying an existing one to suit the Elan.
Re: Track rod ends
Postby mnemonix » Sun 03.05.2009, 10:46
Still available from SJ at £66.90 each.
Any news? One of mine has some play in it now so I'll be looking to replace them by the next MOT in June...
mnemonix
Re: Track rod ends
Postby Specky » Fri 02.10.2009, 17:02
Has any body identified the boot?
Anyone know where to get one please?
Any one got a serviceable old one they don't require?
I split one boot on removal... :roll:
TIA
Re: Track rod ends
Postby GeoffSmith » Fri 02.10.2009, 17:41
Specky wrote:Any one got a serviceable old one they don't require?
Yep!
... and it's got your name on it.
Re: Track rod ends
Postby Specky » Fri 02.10.2009, 17:52
Ta very much...
Malvern Mister...
Re: Track rod ends
Postby GeoffSmith » Fri 02.10.2009, 17:54
I was posting as you were PMing.
:-D :-D
You were posting as I was PMing.
Malvern it is or Hen an Chicken if you want it slightly earlier.
Re: Track rod ends
Postby Specky » Fri 02.10.2009, 18:01
Malvern will be grand... :D
Re: Track rod ends
Postby John_W » Fri 02.10.2009, 21:07
If it's any help, I see from my spare parts list that I bought some suitable boots off eBay in June 2006.
£4.50 for a set of four rubber boots for Massey Ferguson / Fordson tractor track rod ends from ebay seller malcolmhipperson.
I believe it was Monty who posted on here about them.
Re: Track rod ends
Postby GeoffSmith » Fri 02.10.2009, 21:21
Like these for £4.
Re: Track rod ends
Postby GeoffSmith » Fri 02.10.2009, 21:51
These look mighty close. Has anyone got a Landy or
Image?
Re: Track rod ends
Postby bobbrown » Fri 02.10.2009, 22:14
Take your pick Link do not know which one if any will fit any one have one and care to measure it.
Pacific Blue N/A
Re: Track rod ends
Postby Specky » Fri 02.10.2009, 22:31
14mm small
28mm big
20mm height
measurements near as damit
Re: Track rod ends
Postby bobbrown » Fri 02.10.2009, 22:43
As they are rubber and will stretch a bit may be the last one will do the job
Pacific Blue N/A
Re: Track rod ends
Postby GeoffSmith » Sat 03.10.2009, 10:22
bobbrown wrote:As they are rubber and will stretch a bit may be the last one will do the job
According to SWP's old site, they appear to be off a Metro.
Re: Track rod ends
Postby Monty » Sat 03.10.2009, 14:17
Specky wrote:14mm small
28mm big
20mm height
Have a look in the parts cross ref section :poke:
