by bobbrown » Fri 24.04.2009, 18:15
A simple check on the front is to either remove the pads or push the caliper piston back a little bit and see if the outer half of caliper moves freely in and out.
With the rear you can not push the piston back as it has rotate to return it but if you remove the bolts that hold the pins and the caliper the pins should slide freely, chances are they do not.
Pacific Blue N/A
