Denny wrote:My suspension is now 19 years old and never been updated from, what I can see, and I am very tempted to get this upgrade as it seems to be a fantastic deal, but I am not sure I will see the benefit as I only want them for road use. I have looked at SJs website and you can get a full set of springs (front 20% uprated) and fully adjustable aluminium dampers for about £530 delivered. I know they wont be the same quality as the proposed set up, but they would probably last me for a lot of years. My question is; has anyone fitted the SJ set up and if so, are they any good? I assume they are an improvement from the OE set up.
RayD wrote:Bob,
Are the springs that Eibach specified 20% stiffer than the original SE springs?
Nige wrote:I don't think, but cannot be certain that the stiffer springs SJ's sell are simply federal springs re labelled.
bobbrown wrote:Oh I see a hi jack
If you want to run a group buy for springs start your own thread
you wrote:
I did look at getting springs made by Eibach for the Elan to fit the standard spring seats but the cost was prohibitive at £250.00 each spring!
and I wrote wrote:
... if they are otherwise ordinary and any benefit can be gained from it ... Turton’s in Sheffield ... can make a batch of them ... for about £20 each.
bobbrown wrote:The rear of the car has two spring rates a slightly lower one until the helper spring is fully compressed and it gets a little complicated as the formula for two springs is s1*s2/s1+s2 when the two springs are working together but once the helper has gone coil bound it is just the main spring. So say a 150 lb/in and a 200 lb/in spring gives about the equivalent of a 85 lb/in spring until the transition point is reach when it returns to 200.
RayD wrote:Does this mean a 200lb/in spring needs 200lb to compress it 1 inch, and a 150lb/in spring needs 150lb to compress it 1 inch but when they are placed end to end they only need 85lbs to compress them 1"?
