Front Brake Replacement FOUND
Re: Front Brake Replacement FOUND
Postby ESM » Fri 07.11.2003, 12:30
Based on the overlaps measured by both Dave & Dimitris the pads will indeed go right to the edge of the disc with no margin. But that's just right isn't it...? :)
ESM
Postby Doug » Fri 07.11.2003, 18:38
I just love the irony in the title of this thread!!   [smiley=bonk.gif]
Postby Avonvilla » Sat 08.11.2003, 03:09
I've just reread the entire thread and no one has actually said the've tried or are going to try the corsa 260mm discs ? anyone ?
Avonvilla
Postby Dimitris_GR » Thu 13.11.2003, 09:14
[quote author=AV8NDOC link=board=suspension;num=1057127333;start=120#121 date=11/07/03 at 09:38:11]I just love the irony in the title of this thread!!   [smiley=bonk.gif][/quote]Thanks Doug...  :-[
Dimitris_GR
Postby ESM » Thu 13.11.2003, 10:27
[quote author=Avonvilla link=board=suspension;num=1057127333;start=120#122 date=11/07/03 at 18:09:49]I've just reread the entire thread and no one has actually said the've tried or are going to try the corsa 260mm discs ? anyone ?[/quote]<br>I've ordered a pair.<br><br>Here's the story of the thread in smileys:<br><br>[smiley=banana.gif]<br>[smiley=aeh.gif] [smiley=blahblah.gif]<br>[smiley=1poke.gif] [smiley=argue.gif] <br>[smiley=blahblah.gif][smiley=all_coholic.gif][smiley=bawling.gif][smiley=blahblah.gif][smiley=blahblah.gif][smiley=blahblah.gif][smiley=blahblah.gif][smiley=blahblah.gif]<br>[smiley=blahblah.gif][smiley=blahblah.gif][smiley=blahblah.gif][smiley=blahblah.gif][smiley=blahblah.gif][smiley=all_coholic.gif][smiley=bawling.gif]<br>[smiley=2gunsfiring_v1.gif] <br>[smiley=bebe.gif] [smiley=bleh.gif]  (Doug's contribution)
ESM
Postby westonben » Thu 13.11.2003, 14:40
This thread is the longest on the whole forum!<br><br>Alan,<br><br>Where from and how much were the discs?  When will they arrive?  When will you fit them?  When should we expect your report?<br><br> [smiley=surprised.gif]<br><br>Ben
westonben
Postby ESM » Thu 13.11.2003, 18:56
I got the discs, and some Green-stuff pads, from http://www.motorsportworld.co.uk/. I went for the EBC turbo discs but they do Black Diamond, and probably others, as well. <br><br>I expect them to arrive over the next couple of days<br><br>I'll fit them when I can get access to the car lift<br><br>I'll report back (I hope joyfully) after the drive home!<br><br>It seems quite a good site and they do discounts for clubs. Maybe we should get onto them and propose a section for the Elan?
ESM
Postby ESM » Thu 13.11.2003, 19:01
Oh yeah and if you want to see a long thread look at the chatter from the midlands guys in the UK events section...<br><br>Those guys can really type.... [smiley=bowdown.gif] [smiley=blahblah.gif]
ESM
Postby Sy V » Thu 13.11.2003, 19:37
It was 16 pages but I edited some of my one-liners out a couple of weeks ago.<br>We're just sociable folks 'round these parts Alan.<br> ;)<br>I was going to do the same for other people's but it  reflects in your postings total and I may have affected folk's status so I just trimmed mine.
Postby ESM » Tue 18.11.2003, 08:08
At last I have some discs! It might take a while to get them fitted as I don't have access to the car lift for at least 2 weeks :-/
ESM
Postby DeeAitch » Mon 01.12.2003, 14:15
Alan, you have mail :)
DeeAitch
Postby ESM » Sat 06.12.2003, 22:23
[smiley=bonk.gif] [smiley=censored.gif] [smiley=cussing.gif]<br>The 260mm Corsa disc isn't big enough, at least not with the green-stuff pads. The installation had a 3 or 4mm overlap :(.  The disc also needed shimmed as the i.d. of the bell was bigger on the Corsa disc by 3.5mm.  The pads were mutilated to allow me to use the new callipers and discs anyway but its a bit of a bodge-up. I'll probably return to the Clio discs although Dave is hopeful that he might identify a different pad geometry to solve the problem - which would be better. <br><br>The new brakes do stop better, I gained some confidence with them on the back roads near home and they certainly bite. I get a nice buzz from the grooved discs as well.<br><br>Many thanks to Dave for the use of the lift and doing ALL the work! <br><br>Alan
ESM
Postby DeeAitch » Sun 07.12.2003, 12:50
Alan,<br>Glad the confidence improved on the way home :) Checked the profile of your pads with mine and they are identical  :o I think this now points to the calipers [smiley=banghead.gif]. Did you record the casting marks, parts numbers etc? If you can advise which car they were from I will cross check.
DeeAitch
Postby ESM » Mon 08.12.2003, 08:28
Ok from a photograph I can see the codes<br><br>FN52/24R  & CN(?)978 (right caliper)<br><br>FN52/24L  & CN977 (left caliper)<br><br>There's a longer code in smaller writing as well but I can't read it from the photo, I'll have to take the wheel off to read it.<br><br>Alan<br>
ESM
Postby ESM » Mon 08.12.2003, 11:16
On reflection I suppose its the carrier rather than the caliper that's important, the numbers above are taken from the caliper. Perhaps a trip to the scrappy to measure up the offset between the sliding pins and the mounting holes of the carriers from a few different Vauxhall ATE installations is in order. I still think they all should be the same, otherwise the Nova -> Astra/Cavalier/Calibra ATE 16v upgrade wouldn't work...<br><br>By the way the Clio disc solution also looks dubious. These discs have a 3mm greater offset from the mounting face to the rear surface of the disc. I thought this could be corrected by using 3mm spacers on the caliper, however, the disc would touch caliper mount on the hub carrier - there is very little clearance (around 1mm) with the standard discs. The disc could be shimmed by 3mm at the mounting face instead but this would offset the wheel outwards as well.
ESM
Postby DeeAitch » Mon 08.12.2003, 23:32
Mine have the same "FN" Nos but 971 (L/H) & 972 (R/H)<br>Also 361.1 (L/H) & 361.2 (R/H).<br>Looks like the carrier, do you recall which car they came from? <br>3 options?<br>1. Return to warm ;) Washington and try one of mine for size :-*<br>2. I have a template from my carriers. Offset looks to be approx 37mm. I can post a copy.<br>3. Spend a rather cold day at the local scrappy :(<br>If 1 fits then I will arrange an "exchange" for your butchered EBC's :D<br>Agree with your thoughts on the Clio option.
DeeAitch
Postby donald » Mon 22.12.2003, 14:46
Hi,<br>       I have not been on this site for quite a while,<br>  I like the format.<br><br>   Anyway - I have currently the GSI calipers <br>and Volkswagen G60 Discs on my Elan.   The<br> Discs were lathed down from 280 to 270 ish <br> by a co-worker. Everything seems to be working fine.<br>    My co-worker swore never to do the lathe-work<br> again - cast-iron is nasty stuff to work on. <br><br>    I have no spacers - I used the standard bolts.<br>  The whole lot fits within a 15" wheel.<br><br>  The only worry I had was that the centre of the<br> disk was 4mm larger than the ring on the hub.<br>   After 1000 miles the disk retaining screws have not<br> budged - so I take it they are under no strain - all<br> the energy being transmitted by the bolts.<br><br>   If I had another go I would try the corsa? ones<br>first.
donald
Postby Avonvilla » Wed 24.12.2003, 23:25
I know this is gonna sound kinda obvious but cant hi-spec supply the discs ?
Avonvilla
Postby DeeAitch » Tue 01.06.2004, 13:11
All my previous measurements regarding 2mm overhang were taken from the R/H caliper. This weekend I had reason to check the L/H side (Finally got around to Gearbox oil but that's another story ::)). <br>Horror, the overhang is 4mm :o Looks like a tolerance issue.<br>Alan, this seems to support the findings from last year :(
DeeAitch
Postby KevH » Tue 01.06.2004, 17:14
I've fitted ATEs from a '96 Daewoo Nexia, with standard disks. The pads overhang 2mm (same at both sides).<br>Apart from the fact that you know this does'nt look quite right, can anyone give me a good technical reason why its not acceptable.<br>After all the brakes work much better than the standard items which is the whole point of the excercise.
Wot no Loti
KevH
