Bilstein/Eibach suspension Version 2
Re: Bilstein/Eibach suspension Version 2
Postby bobbrown » Mon 01.02.2010, 12:43
RayD wrote:You’re right Bob, I wasn’t expecting they did – it was the only thing I could think off that would account the motion ratio affecting the spring rate differently from old to new. I’m sorry about that.
The motion ratio only has to be taken into account when looking at wheel to spring loads the ratio does not change
RayD wrote:I made this point earlier, it’s hardly worth bothering making a miniscule adjustment to the spring rate to account for the effort in turning the wishbone if the rate is going to randomly increased later.
As with all these things it is a compromise unless you want to get special springs made which just bumps the price up, better to select the nearest off the shelf part.
Here is a range of springs rates that could be fitted to the front
This is by no means that accurate as none of the other factors has been taken into account like spring pre load or the dynamics of the whole but it does give an idea of the range that is possible but I would be inclined to use the centre half a dozen so from 263.8 lb/in (closest 250 lb/in), softer than standard to 591 lb/in (closest 600 lb/in) the latter being a race setup and may require a visit to the dentist if used on the road.
It follows the rear should be similar but the rates will be typically just a tad over half the front and should go up in relation to front as it would not be a good idea to put the same springs on the rear as the front.
Pacific Blue N/A
Postby RayD » Sat 13.02.2010, 11:13
I had a reply from Lotus with regard to the spring rates … unfortunately it was only to explain the “company policy not to divulge spring rates on Lotus Cars”
Postby bobbrown » Sat 13.02.2010, 11:16
Not in the least bit surprised
Pacific Blue N/A
Postby thewheelrestorer » Mon 15.02.2010, 20:24
I can't believe this suspension development is still faffing about...................
And now it's over a grand+
Pity the KW lead wasn't looked at, and now you''re looking at Nitron!
It must be coming up for 2 years soon ?
TWR
thewheelrestorer
Postby Dico » Mon 15.02.2010, 21:44
Patience is a virtue numbnuts.
Oh, and its actually completed now.
Postby Elanlover » Mon 15.02.2010, 22:53
thewheelrestorer wrote:I can't believe this suspension development is still faffing about...................
TWR
Actually just over 1 year now. And, interspersed were the brake, wishbone and Elise steering wheel adaptor projects. And that's just what I know of and doesn't include anything else Bob's gotta do in his life since these are free time projects.
Not sure what you're trying to say with your Nitron comment. Are you saying they aren't worth looking at or just suggesting that a change in supplier is a bad idea? Or that somehow KW is better? None of the above I hope. :smt096
Postby bobbrown » Tue 16.02.2010, 00:04
TWR
And a KW kit was going to work out a lower cost option? I think not as the Elise offering is £1,235.79 and the mounts are a lot easier.
At the end of the day you pay for what you get if your happy with low cost twin tube dampers carry on.
Pacific Blue N/A
Postby Nige » Tue 16.02.2010, 00:12
TWR
And thank you for your useful contribution :shock: ,
Back in Blighty
Nige
Postby XiPHiAS » Tue 16.02.2010, 01:09
I'm still working with KW for a solution for the Elan...
i'm from 2 steps to the order off the special made KW variante III with 4HLS system for my Elan.
With the HLS system ((Hydraulic Lift System) I can go lower ... and rise the car with a push on a button for 45mm
http://www.youtube.com/watch?v=u92ucshOEVw
1994 Lotus Elan S2 #131 // Lotus Elan M100 S2 Registry
http://www.lotusforum.be :: Benelux Lotus Community
Ypres Lotus Day - International Lotus gathering & tour
XiPHiAS
Postby bobbrown » Tue 16.02.2010, 12:33
XiPHiAS wrote:I'm still working with KW for a solution for the Elan...
At what sort of price?
I have a feeling it is going to be 3000 euro's plus which put it out of almost all peoples pockets.
BTW: Watch the front wheel to wheel arch liner clearances as there is not much room to play with and it is important to maintain a clearance on full bump.
Pacific Blue N/A
Postby rip » Tue 16.02.2010, 21:09
Dico wrote:Patience is a virtue numbnuts.
Either that or the Elan you drove the other week (with the carbon rear panel :smt023) was being supported by Jedi force :shock:
Postby bobbrown » Wed 17.02.2010, 00:53
whats this
and some on the rear
Pacific Blue N/A
Sweet!
Postby tigerdog » Wed 17.02.2010, 05:15
Looks like business. Now put on your wetsuit and scuba mask and start scrubbing that undercarriage like Nitroman! :lol:
Re: Sweet!
Postby rip » Wed 17.02.2010, 09:10
tigerdog wrote:Looks like business. Now put on your wetsuit and scuba mask and start scrubbing that undercarriage like Nitroman! :lol:
:oops:
Won't ever be as good as that but condition is improving all the time...honest!
Postby XiPHiAS » Thu 18.02.2010, 11:07
~1800 (suspension based on the variante III)
(I know the HLS is an expensive option, but I think i'll take it :))
XiPHiAS
Postby bobbrown » Thu 18.02.2010, 13:31
Is the 1800 euro's?
Even if it is it is still amost half as much again as the Nitron setup and you could always add the HLS to that.
Pacific Blue N/A
Postby XiPHiAS » Fri 19.02.2010, 00:00
bobbrown wrote:
Is the 1800 euro's?
I have more trust in KW than Nitron ...
XiPHiAS
Postby rip » Fri 19.02.2010, 11:20
I was quite impressed with Nitron's setup & knowledge when I was there having the prototype fitted.
Postby Don.Hasi » Fri 26.02.2010, 18:34
Xiphi: is the development only for the Var III?
@bob: i get a stock suspension in April. Then I could measure it completely.
Don.Hasi
Postby bobbrown » Fri 26.02.2010, 21:48
I am hoping to have this done and dusted by then or at least as far as the group buy is concerned but it will still be available but at a higher cost.
Pacific Blue N/A
Users browsing this forum: Bing [Bot] and 3 guests
