Rambo wrote:Over the years I've owned 4 VW Golf Gti's (including a Mk4) and, not only have they all been extremely reliable and bombproof, but I've never ever had any problems with the calipers leaking
Jamie N wrote:Rice crispy wrote:Jamie, I assume you had to make new mounts for the calipers and handbrake?
I made up new 6mm brackets and drilled them corresponding to the Honda carriers and the mounting points
on the Elan hub as in the picture, the bracket for the handbrake cable needs a bit reshaping in order to clear the
back of the hub, nothing major though.
The 2nd picture shows how easily pads are changed by simply swinging the caliper up, no springs or jammed pins
to deal with on these, and the other great thing is being fairly recent, they will be available for plenty time to come,
and cheap, you could even pick up a pair of used ones in good condition for less than a hundred quid. Just doesn't
make sense to spend several hundred on calipers known for leaking when you could have superior rear brakes
for a fraction of the price. I have had 2 Elans with these go through MOT, both passed way above the minimum level required.
