by ESM » Mon 19.07.2004, 23:57
[quote author=John_W link=board=suspension;num=1057127333;start=150#158 date=07/19/04 at 14:56:29]<br>[smiley=eek2.gif] <br>Alan,<br><br>It is only my concern for somebody who has become an Elan superhero which prompts me to post in this thread, but I fear that you seem to know more about this subject than is good for your sanity. <br><br>Please try to get out more and then maybe they can reduce the medication.<br><br> [smiley=crazy.gif] [smiley=crazy3.gif] [smiley=dark2.gif] [smiley=dazeda.gif] [smiley=bonk.gif] [smiley=help.gif] <br><br>John<br><br>[smiley=why_me.gif] [smiley=disbelief.gif] [smiley=sad2.gif] [/quote][smiley=all_coholic.gif] [smiley=crazy.gif] [smiley=crazy3.gif] [smiley=damaged.gif] [smiley=dazeda.gif] [smiley=dazeda.gif] [smiley=drunk.gif] [smiley=dontknow.gif] [smiley=help.gif] [smiley=lol2.gif] [smiley=jar.gif]
ESM
by KevH » Mon 04.04.2005, 08:55
[quote author=junks link=board=suspension;num=1057127333;start=150#154 date=07/19/04 at 11:14:42]Wasn't thinking of buying them but if the disc's are 288mm 24mm thick & 41mm offset with 4x100 PCD then it'd be nice to know what they are from because I haven't found any that size yet :P[/quote]<br><br>The disks are 5 stud with extra holes drilled to suit our 4 x 100mm configuration with one of the original holes slotted. They look like a colander. <br>Spacer is needed as Astra, Nova, Corsa and Elan have 56.6mm spigot, 5 stud Calibra, Vectra etc have 60.0mm spigot.<br>Kev
Wot no Loti
KevH
by piston_broke » Sat 23.04.2005, 18:24
How about changing the front hub carrier ;D assuming it's probl'y a flipping astra/cav jobbie anyway, then the astra/cav calipers would fit perfectly<br> [smiley=crazed.gif] [smiley=bonk.gif] [smiley=all_coholic.gif]<br>just trying to help<br>d
You came in that thing? Your'e braver than I thought!
piston_broke
by piston_broke » Sat 30.04.2005, 21:32
261x24x41x4 any good?<br>corsa 1.7 dti vented disc £22.56 each<br>sorry if anyone else has said these but could't be arsed to read all the posts again<br>cheers<br>d<br><br>sorry, reread it and they have already been mentioned :-[
piston_broke
by piston_broke » Tue 03.05.2005, 17:44
[smiley=lol2.gif]<br> ;Dd
piston_broke
by F1 LOTUS » Fri 06.05.2005, 06:02
New from AP!<br>Currently only available for WRX's and EVO's <br>Eh Doug[smiley=1poke.gif]<br>
<br>Full story<br>http://www.pistonheads.co.uk/news/default.asp?storyId=10539
F1 LOTUS
by Doug » Fri 06.05.2005, 20:45
[quote author=Brian_MDB link=board=suspension;num=1057127333;start=165#166 date=05/05/05 at 22:02:25]New from AP!<br>Currently only available for WRX's and EVO's <br>Eh Doug[smiley=1poke.gif]<br>
<br>Full story<br>http://www.pistonheads.co.uk/news/default.asp?storyId=10539[/quote]<br>Thanks, I'll get them when my money tree is big enough to bloom :-/<br><br>I like the dirty Evo caliper sitting on the disc. Must be off an Evo cause of the crappy looking paint, but don't get me started on that . . .
- LEC Founder
by F1 LOTUS » Fri 13.05.2005, 19:13
[center]BRAKE UPGRADES AVAILABLE<br>ORDERS BEING TAKEN IN<br>'ELAN PRODUCTS' SECTION![/center]
F1 LOTUS
by piston_broke » Mon 15.08.2005, 14:44
so, God help me for dragging this up again, but has anybody tried the corsa 1.7dti discs with the gte calipers yet?
If not, I may have a go
cheers
d
piston_broke
by chris22 » Mon 30.01.2006, 21:22
i fail to see why this overhang of the pad is such a big deal. it seams to me that it is anywhere between 1 and 4 mm to the out side of the disc.
if it is just 1 mm then it will be so thin that as the pad wears it will just break off not a prob.
if it is as much as 4 mm then why not just mark the unwanted material and then remove it using a bench grinder.
i intend to try this as soon as i can get hold of some calipers from a 16v gsi cav or calibra form my local breakers.
on another note when replacing the pads and discs i had a lot of fun trying to find parts anywhere apart from lotus i eventualy found the discs to be vauxhall cav 91 on 2.0 i and the pads to be the same as that fitted to a early nova van. these fitted the brakes do feel a little hard but will lock with efort. think the crap feel is down to crap standard calipers so cant wait to get rid.
chris22
by DeeAitch » Mon 30.01.2006, 22:51
Ah, the infamous thread
Yes! You still get overhang. Amount depends on the pads. As you say this can be 1 to 4 or even 5mm. OE pads tend to be close to the edge of the backing plate while 'weatabix' can be 4-5mm inside. This was researched to death here finally resulting in the fine efforts of Brian and Alan on the Wilwood setup (which incidently I have now seen 'in the flesh' and the quality, particularly the rotor hats/ brackets, is amazing
). If you are determined to go the ATE way then you might want to consider the Vectra V6 option. 284 or 288mm Discs are available in 4 stud if you shop around(one of many
http://www.courtenaysport.co.uk/default.htm?page=24). You still get the overhang tho'
and will possibly need 16" wheels.
DeeAitch
by chris22 » Thu 02.02.2006, 19:55
just to let you all no found fome ate calipers from a 94 cav 2.0 16v
fitted them today the pads do over hang. however cant see a problem in ths ive now done fifty miles and the only change is that i now have brakes that work!!!!!
chris22
by a5gcd » Sun 05.02.2006, 20:16
chris22 wrote: the pads do over hang.
How much do they overhang? Can you post some pics?
Geoff
a5gcd
by Andy C » Wed 15.02.2006, 03:03
Found here
http://www.lotuselancentral.com/lec/commonparts.htm
This
I have been corresponding with Mark Joseph at Disc Brakes Australia (DBA) about our Elan front rotor.
It seems with the specs and measurements I've emailed him, he has matched the Elan rotor to the GM/Opel Calibra.
They have this replacement in their DBA “Longlife Slotted” rotor.
The price for Longlife slotted would be US $85.00 each, plus shipping.
The Part Number is “DBA 023” and the weight is 5 Kg’s each.
Has anyone tried these? .. Do they fit and work better than the standards. Price for the slotted and X drilled = $AUD170 (about 70 quid) from the one supplied I spoke to.
Sorry if this has been answered before .. I tried wading through the nine pages, and couldn't find the answer.
Andrew
Medina Green #296 Brians Wilwood Brakes, Everest Chip, Piper 2.25, PWR Cooling & ProTech Suspension
Andy C
by pjohn151 » Wed 15.02.2006, 09:35
Yes they should fit. Standard front discs are the same as UK Vauxhall Calibra and other contemporary Vauxhall/Opel models as well as some Protons as I remember.
SOLD - '90G BRG Elan SE, 42k miles
Excellent condition - see for sale section
Now Elanless
pjohn151
by mickmick » Tue 06.06.2006, 10:40
bump
just for a laugh really
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum
mickmick
