16" Wilwood bolts
Postby Dico » Sun 20.01.2008, 19:14
geoffsmith wrote:don't forget that you are all empowered (I wish I hadn't said that, I hate HRbollockspeak
Rooster says you can't say brainstorm anymore either as its discriminatory to people with mental problems. Gary?
Looks like theres quite a bit of loctite on there Paul. Careful you don't put too much on as aparently it can affect the tourque figure.
Postby GeoffSmith » Sun 20.01.2008, 20:35
I guess blue sky thinking is OK though. :twisted:
Postby nitroman » Sun 20.01.2008, 22:28
Point of reference... below is the description of racepartsusa.com Wilwood big-brake kits, and is COPIED DIRECTLY from the description of Wilwood's own brake kits. Anything above grade-8 is most likely gravy, especially considering the Elan's relatively light weight. That said I think anyone who buys used brake parts is taking a risk I wouldn't... just so you know I'm not an extremist on this topic.
Caliper Brackets and Hardware
Aluminum mount brackets with steel threaded bolt hole inserts are lightweight and strong. Each bracket is CNC machined for precise fit on each specific spindle. Grade 8 strength or higher nuts, bolts, washers and alignment shims are included in each kit.
While racepartsusa.com supplies "Q" compound pads with its kits, whilst Wilwood's own brake kits are supplied with PolyMatrix 7112 "T" compound pads. racepartsusa.com supplies kits for imported compact cars, whilst Wilwood's kits are for heavier "classic" full-size Detroit iron.
Wilwood's torque specs can be found at the bottom-right of this page... http://www.wilwood.com/PDF/ds449.pdf
nitroman
Postby nitroman » Mon 21.01.2008, 02:49
Interesting. But I wonder if these are truly functional, or just allow you to die in style.
http://www.wilwood.com/featured5.html
nitroman
Postby RichyP » Tue 22.01.2008, 00:02
Paul,
The bolts and washers arrived today. Thanks for your help, much appreciated! Think i'd have been well stuck without it!
Rich
RichyP
Re:
Postby tigerdog » Mon 17.08.2009, 15:46
nitroman wrote:Grade 8 strength or higher nuts, bolts, washers and alignment shims are included in each kit
Please note: Grade 8 is an SAE hardness scale. It's metric equivalent is Class 10.9, not 8.8. Metric Class 8.8 = US Grade 5.
