Alternate willwood brake upgrade with dust seals
Re: Alternate willwood brake upgrade with dust seals
Postby Monty » Sun 07.09.2008, 12:24
Nice work bob :smt023
Look forward to seeing the set up at Hethel :wink:
Postby F1 LOTUS » Sun 07.09.2008, 22:32
Looking good 8)
F1 LOTUS
Postby bobbrown » Wed 10.09.2008, 17:05
Eureka!
Have now completed the prototype Dynapro (Midlite) caliper for the 15" OZ rim
Clearances were as I suspected a little tight but is does clear about 1 to 1.5mm clearance this is only in one small area where the spokes curve in, reat of the clearances are fine.
I may look to increase this clearance by machining a little of the top of the 3/8" UNC cap screw (silver heads in picture) or possibly just chamfer the top as it only requires a little bit removed.
It would be easy to supply a set of cap screws with the bracket.
The hex bolts holding the bracket to the hub are only temporary as the bracket is designed to use the existing cap screws.
Pacific Blue N/A
Postby nitroman » Wed 10.09.2008, 21:53
Looks good Bob. What is the rotor width you are using; 1.1", 1", or .81"?
Also, what is the weight of your 1-piece rotor? Just wondering how that compares with the weight of the Wilwood rotor & aluminium hat used on the 15" kit, since it is all unsprung weight as well as rotational mass which consumes engine power to spin.
nitroman
Postby bobbrown » Wed 10.09.2008, 23:14
The standard disc is 5.2kg + caliper at I think 3.5Kg but will check + pads total around 9 to 9.5kg
15" one piece discs 276mm x 24mm weight 6kg + caliper at 1.7kg + bracket + pads total around 9 to 9.5kg
16" one piece discs 294mm x 24mm weight 6.4kg so the whole lot is 0.4 kg heavier than the 15"/standard setup
If you were concerned about weight some material could be removed from both the 276 and the 294 discs in an area that is not swept by the pads but the reason for not doing this is they would need to be re-balanced.
As for the Wilwood 15/16" kits using the powerlite and dynalite calipers I have no idea OK they are going to be lighter but by how much I do not know probably not that much the discs weigh 3.5kg and 4kg respectivly you then have to add in the bolts (hat to disc) + the hat/bell. We could assume there is only a small differance in caliper+pad weights. So I would say the two piece disc kit probably saves 1 to 2 kg over the single piece disc.
The single piece disc does have some advantages over the two piece kit one it's cheaper and second the disc is thicker.
Plus lets not forget the caliper, the dynapro (midlite) has dust seal making the kit more comparable to the Hi-spec kits who I think use the same discs.
Pacific Blue N/A
Postby nitroman » Thu 11.09.2008, 00:56
bobbrown wrote:As for the Wilwood 15/16" kits using the powerlite and dynalite calipers I have no idea OK they are going to be lighter but by how much I do not know probably not that much the discs weigh 3.5kg and 4kg respectivly you then have to add in the bolts (hat to disc) + the hat/bell. We could assume there is only a small differance in caliper+pad weights. So I would say the two piece disc kit probably saves 1 to 2 kg over the single piece disc.
I have a spare set of the 16" hats/rotors/bolts already assembled. The next time I have to go to the post office I'll have them weigh it under the auspices of 'shipping' it.
Wilwood lists the weights of all their "2-piece" rotors online, but suspiciously eliminate that stat from all three styles of their 1-piece rotors.
nitroman
Postby Elanlover » Thu 11.09.2008, 01:07
I'll be interested in knowing if i could use this setup (calipers and mounting bracket) with the existing rotors that Brian spec'd for the original Wilwood upgrade (I've got 16" wheels).
Postby F1 LOTUS » Thu 11.09.2008, 02:21
Elanlover wrote:I'll be interested in knowing if i could use this setup (calipers and mounting bracket) with the existing rotors that Brian spec'd for the original Wilwood upgrade (I've got 16" wheels).
:smt033
Not a chance I'm afraid - dust-sealed calipers are a fair bit wider than those without :cry:
F1 LOTUS
Postby bobbrown » Thu 11.09.2008, 08:33
I do not think so as the caliper is 6mm wider from outboard disc face.
The problem with a 2 piece disc is the mounting bolts, discs to hat/bell, these tend to run in way of the caliper mounting bracket and as such do not allow the disc to be moved inboard any more than it has been by Brian and co.
A single piece disc does not have this problem thus allowing it to be moved further inboard, the only constaint then is the lower ball joint.
If you look at the picture you will see what I mean, you have to get the head of the bolt between the caliper mounting bracket and the disc, in the case of a solid disc this clearance is 3 to 4mm
Pacific Blue N/A
Postby bobbrown » Mon 15.09.2008, 10:46
I have just done some checking with regard to caliper sizing for this upgrade and have found an error with the original upgrade that isn't really an upgrade.
I now feel that the caliper piston size need to be 38.1 mm (1.50") not the 35.1mm as was used in the original kits this give an approx 30% increase in tyre force over standard.
Pacific Blue N/A
Postby bobbrown » Mon 15.09.2008, 12:59
I have redone the graph of the brake upgrades Wilwood and Hi-spec and I have come to the conclusion that the Dynapro calipers need to be with 38.1 pistons not 35.1
Pacific Blue N/A
Postby Nige » Mon 15.09.2008, 14:44
Bob, your kit looked great on the stand, thanks for bringing it I think it will be a very popular and worthwhile upgrade, particularly for those who haven't yet upgraded or for those such as me who have had to make some small compromises (such as spacers) with earlier upgrade options.
Back in Blighty
Nige
Postby rip » Mon 15.09.2008, 22:56
Nige wrote:I think it will be a very popular and worthwhile upgrade, particularly for those who haven't yet upgraded.
:agree: It's on my project creep list :-D
Postby tigerdog » Tue 16.09.2008, 14:10
Bob, I especially appreciate the time and analysis you're putting into this. Your comment at the stand about radial mounts allowing fine adjustment made lots of sense - something I hadn't thought about before. Good job!
Postby mnemonix » Sat 04.10.2008, 20:59
Bump... what's the status of Bob's Willwood upgrade ? He told me a couple of weeks back that he was putting the 15" kits together that weekend, but I haven't heard anything since. Are they available yet ?
Chris.
mnemonix
Postby CJ101KT » Sat 25.10.2008, 12:58
I am also interested in this kit for my stock brakes I have under my S2 16" wheels ... if these are available before the NEC Classic Car Show I would be so happy and even promote your kit when my cars on the stand ...
CJ101KT
Postby CJ101KT » Sat 25.10.2008, 14:57
CJ101KT wrote:I am also interested in this kit for my stock brakes I have under my S2 16" wheels ... if these are available before the NEC Classic Car Show I would be so happy and even promote your kit when my cars on the stand ...
Also do Wilwood do red calipars? :smt029
CJ101KT
Postby bobbrown » Sat 25.10.2008, 16:36
The 16" version is a done deal
Monty now has them fitted and will find out on Tuesday what they are like on the track.
The 15" got put back a bit as I was working on the rear hubs and wanted to get that little project finished but I will be back on to the 15" version next week.
The standard colour is black but no doubt you could spray them any colour you like (caliper paint)
Pacific Blue N/A
Postby Elanlover » Sat 25.10.2008, 17:23
You can get pretty much any Wilwood caliper in red. The details are on their website with their product numbers. (I think you add "R" to the end of the product code)
Postby CJ101KT » Sat 25.10.2008, 17:26
Are you selling the kit or do I need to purchase the necessary parts from Wilwood? (online?)
CJ101KT
