dapinky wrote:I think you'll find that Switzerland and Sweden are not the same place![]()
If you want to spend some time reading instead of writing, may i suggest you look at some of the discussions in these threads (and there are quite a few others if you can be bothered to use the search function):-
viewtopic.php?f=41&t=17770&p=232885&hilit=brake+efficiency#p232770
viewtopic.php?f=23&t=24765&hilit=brake+efficiency
viewtopic.php?f=41&t=23606&p=297334&hilit=brake+efficiency#p297334
viewtopic.php?f=41&t=22545&p=284159&hilit=brake+efficiency#p284154
viewtopic.php?f=41&t=20813&p=264458&hilit=brake+efficiency#p264268
dapinky wrote: ....after all, we all know that 86.7% of statistics found on the internet are purely inserted to make a point appear valid.
Elanlover wrote:dapinky wrote: ....after all, we all know that 86.7% of statistics found on the internet are purely inserted to make a point appear valid.
Now that's a stat I believe in!
Yes, and even the different valves stages alone make it impossible to give a single coefficient as it's not linear. And I don't see why it would be stupid to want a non linear bias ^^dapinky wrote:There is no simple coefficient of multiplication
clemo wrote: and can hover my finger over the mute button for 7 days or permanently ( as can any other mod)
How else would you propose to get 80% less braking on the rear? bicycle disks?isuzuowner wrote:A bias valve on a production car is typically a sign of someone in the engineering department not picking the right parts, discovering the error too late, and scrambling to fix that problem too close to the production date.
Dave Eds wrote:clemo wrote: and can hover my finger over the mute button for 7 days or permanently ( as can any other mod)
But this one isn't renowned for having your patience Clemo. I prefer the "bollox" approach so may just hit the button anyway..........
Tiny pistons would probably do the trick but it might not be standard off the shelf. And as I said, as we know the Elan has a non constant bias.Simon_P wrote:How else would you propose to get 80% less braking on the rear?isuzuowner wrote:A bias valve on a production car is typically a sign of someone in the engineering department not picking the right parts, discovering the error too late, and scrambling to fix that problem too close to the production date.
Artaban wrote:Is there an emoji for Waffly Bollocks? I think one is needed.
Simon_P wrote:How else would you propose to get 80% less braking on the rear? bicycle disks?isuzuowner wrote:A bias valve on a production car is typically a sign of someone in the engineering department not picking the right parts, discovering the error too late, and scrambling to fix that problem too close to the production date.
This is quite a light car with the light bits over the rear wheels and the heavy bits over the front wheels.
Giniw wrote:Drums brakes aren't that bad, it's just that the heat dissipates less. Which is a problem indeed, but it's not a lack of braking power.
AnonImouse wrote:Drum brakes. 'tis the future I tell you.
You mean one can't seat in the driver seat?!muley wrote:or have any modifications
which result in a change in or relocation of weight or centre of
gravity
muley wrote:Just FYI
NZ vehicle standards
muley wrote:Can't wait to see if my Elan is compliant.
