MOT failure... any advice?
Postby pjohn151 » Thu 16.03.2006, 14:54
Cheers Sy
I see you can really go to town on these as there is a nice Sealey kit on the website for £57 for doing the same job!
SOLD - '90G BRG Elan SE, 42k miles
Excellent condition - see for sale section
Now Elanless
pjohn151
Postby stevo » Thu 16.03.2006, 16:32
before you retest the car take it out for a good spanking to get every thing hot and freed off. then doing 40 ish slowly pull the hand brake up till you feel it start to bite (don't yank it on and spin off into the other lane) and hold it for a couple of seconds. this will bed them in coz they are used in normal driving very little. after that put a couple of bags of sand in the boot for the next test to help weigh the back down :wink:
stevo
Postby Mike Y » Tue 21.03.2006, 22:20
I,ve just been told Lotus have made the rear pads for the M100 obsolete so you have to buy aftermarket.
Regards Mike :shock:
N.B. Sounds like sticky sliders/pistons to me. If you want any work done locally I know an excellent independant Lotus specialist we are working together. I supply the genuine Lotus parts he supplies the knowledge that comes from being a time served mechanic with loads of Lotus experience and enthusiasm ( He has re built a number of Lotus cars to concours standard) and his hourly rate is low. PM me if you want more info.
Mike Y
Postby Doug » Tue 21.03.2006, 23:52
Sy V wrote:Found the thing.
Caliper Wind Back Tool 52334 Draper CWT1
long url
:smt023
Postby schurch » Wed 22.03.2006, 18:26
Passed.
Looking at it carefuly I'm not convinced they did much at all bar take the wheels off and scrub up the brake pad surface a bit. quite expensive, but at least its through.
Thanks for the advice guys. Mike, I'd definately be interested in putting some work (when I have it) your guys way. Will give you a PM next time I'm in need.
schurch
Postby Mike Y » Thu 23.03.2006, 13:41
No Probs. I am pleased you got your car through the MOT.
Cheers Mike :D
Mike Y
Postby Exbury » Thu 30.03.2006, 16:25
Assuming that the front discs & callipers have been uprated slightly, by putting more power into the fronts, would it not be worth trying to slightly increase the bias towards the rear wheels slightly to help try to offset this problem with the rear brakes failing the MOT?
Say if standard bias is 14-15%, can you consider uprating this to a bias valve of 17-18% to make the rear brakes work slightly more than they do. Plumbing in a valve should not bee too much of an issue, maybe a different bracket? Finding one that is the right % may be the bigger issue.
I know that over-powering the rear brakes could lead to disaster as you do not want the rears more powerful than the fronts, however as the fronts have already been increased, could the rears be increased by a proportionate factor (e.g. for every 10% increased in front power, the rears valve should be balanced by 1.5% more)?
Also (I haven't had the chance to look), is it possible to weld/replace the handbrake arm on the earlier rear callipers to add an extra 5mm or so to add a greater mechanical force to the early SE cars with the unmodified handbrake mechanism?
Thoughts?
Exbury
Postby Mike Y » Thu 30.03.2006, 17:31
I believe the problem with uprating the rear brakes is that Lotus have them set to do the best alround job using their standard suspension set up without sending the car spinning off the road in anything other than fine dry weather. Without changing the suspension to alter the cars dynamic wieght distribution while cornering and under heavy breaking I think you would be playing with fire. Unless you have a test track to test out different settings.
A guy I know took the valves out completely and nearly killed himself at the first corner.
Regards Mike :-D
Mike Y
Postby M100 TWO » Thu 30.03.2006, 18:43
Exbury, you do not want more braking power on the back, in a panic stop all weight transfer goes to the front, the rear wheels go light, more power would only lock up the rear wheels with dia consequences the latest proportioning valve fitted is the (2/15) it works to these ratios of pressure measured in bars
15 bar front =15 bar rear
after that it is 1bar front = 0.2 rear
a panic stop of 85 bar front = 29 bar rear
hope this helps
john
M100 TWO
Postby Guest » Fri 31.03.2006, 09:06
Cheers guys, I wanted to explore the possibility. I guess I will just fit new valves and clean up all the brakes and fit SSteel lines which should all help to pass the MOT
I'm just worried with these really tight regulations that I am going to have to do this each and every year.
Guest
Postby Mike Y » Fri 31.03.2006, 10:13
I dont think you will have this problem every year. Once your brakes are sorted just keep them well maintained. I have never had a problem with any of my Elans failing an MOT on rear brakes, maybe you could try a different MOT station?
Regards Mike :-D
Mike Y
