by muley » Thu 03.08.2006, 14:43
I think Chris T's mechanic found they were like the Herald one but 5mm. narrower?. It seems it could be shimmed out if that is the case..
Jim B
by Ultimatt » Thu 03.08.2006, 14:50
That matches with my experience Jim. Although I wouldn't say they were as much as 5mm out... more 2-3, which is easily 'shimmed out'
M100 Elan SE:
Metallic Gold Fleck Red.
Carbon intake pipes.
Bailey recirculating BOV.
Samco hose kit.
Pro-tech shocks.
S2 wheels.
16" Wilwood Brake upgrade.
S/S Exhaust system.
Everest Chip !
Ultimatt
by muley » Thu 03.08.2006, 14:55
Ultimatt wrote:That matches with my experience Jim. Although I wouldn't say they were as much as 5mm out... more 2-3, which is easily 'shimmed out'
Bingo! That'll do nicely. I'm assuming the taper and mounting bolt holes are the same.
Jim B
by Ultimatt » Thu 03.08.2006, 15:02
The shaft is exactly the same, but the treaded part of the shaft is slightly narrower. Therefore you need an appropriate nut.
The mounting bolts are very slightly closer together which is not a problem locating with the holes on the arms, but the shims will either need modifying (as I did) or replacing with an alternative.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
by muley » Thu 03.08.2006, 15:05
Matt.
Well, as they're only £9.99 inc vat at Rimmers, I'll prolly put up with the minor inconvenience.
by Ultimatt » Thu 03.08.2006, 15:11
Absolutely. If you find an appropriate replacement shim, let me know.
I needed to get mine back on the road ASAP so slotted the existing shims. Would prefer an 'un-modded' option.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
by Monty » Thu 03.08.2006, 15:28
Ultimatt wrote:The mounting bolts are very slightly closer together which is not a problem locating with the holes on the arms, but the shims will either need modifying (as I did) or replacing with an alternative.
Matt
This will make a huge difference with the camber adjustment and u may not beable to get the adjustment plates to fit. Just be carefull
- Chunder King!
by muley » Thu 03.08.2006, 16:06
duplicate post.
Ignore.
Jim B
by Ultimatt » Tue 08.08.2006, 20:24
I've had the full geometry setup done today... camber, caster, toe in etc etc. The replacement upper ball joint was fine and despite the slightly narrower profile has allowed for full adjustment to optimum alignment.
The main adjustment that the joint impacts upon is the caster angle.
Car handles like a dream again now. Just waiting for the new tyres to complete the transformation.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
by Ultimatt » Fri 11.08.2006, 14:29
That ball joint has been put to the test now and performed as original so I am concluding that, despite the slight difference in dimensions, it can be shimmed to the exact adjustments of the original (as the laser geometry alignment proved).
The normal price for the part is £25 + VAT and delivery etc (approx. £45+), but as my mechanic friend can get them discounted, I can get them for anyone that requires one for £25 all inclusive of VAT and delivery (within the UK). Ball joint comes complete with top nut.
As mentioned before, a slight adjustment is required to the shims to enlarge the slots, but this can easily be done with a file or small grinder.
Let me know if I can help anyone out with these or if the moderators want to house this offer in the parts section.
Matt
M100 Elan SE:
Samco hose kit.
Pro-tech shocks.
S2 wheels.
S/S Exhaust system.
Everest Chip !
Ultimatt
