Is it possible to quantify how much effort is needed to operate the caliper lever without using the cable
Make sure there`s a bit of slack in the cables when the handbrake is in the off position.
I'm getting pretty chufed off with all this. Mine didn't leak but really struggled to get through the MOT handbrake test (and they were newly fitted). The tester quite rightly refused to use both hands. I've a mind to get a pair of reconditioned original rear calipers refitted now and right off the Hi Spek rears as a bad experience - no offence to Bob at all, just to Hi Spek for a shoddy product.
could the arm where the cable end connects not be made a little longer which would give a bit more leverage
bobbrown wrote:5kg on the lever should give about 300bar of pressure. Bob
I can not see on the face of it why the hand brake should be weak.
bobbrown wrote:they do not seem valid excuses
Steve A wrote:Yes this is a must, I also found that adding a spring between lever and stop helped the release.
How many clicks are you getting Monty ?
bobbrown wrote:Now all I have to do is get Hi Spec to produce them, now there's a challenge!Bob
