Alternate willwood brake upgrade with dust seals
Re: Alternate willwood brake upgrade with dust seals
Postby Monty » Sun 26.10.2008, 00:35
CJ,
Thought you was on a budget :? getting calipers in red will cost you extra and i would imagine they`d have to come direct from Wilwwod in the states, so would take longer to recieve.
IIRC Bob has to order 2 sets off calipers from Rally Design to get a discount and thats why he can keep the price down slightly.
Here`s a quick pic off BB`s special :-D
Postby bobbrown » Sun 26.10.2008, 00:38
Wilwood do not show them as being in any colour other than black so some caliper paint is called for to get them to red
Pacific Blue N/A
Postby nitroman » Sun 26.10.2008, 01:25
bobbrown wrote:Wilwood do not show them as being in anny colour other than black so some caliper paint is called for to get them to red
Powerlite only come in black.
Dynapro comes in black or red (add ”RD” to end of part number).
Dynalite (RE: 6806,6811,6816) come in black, red, and blue (add ”RD” or “B” to end of part number).
Here's the hue of "Wilwood red"... http://www.wilwood.com/Centers/Photo/Gr ... redsl6.swf
nitroman
Postby CJ101KT » Sun 26.10.2008, 10:42
Monty wrote:CJ,
lol yea ain't it funny how much im willing to spend to get them now, getting all excited! I have opted for the black callipers unless Rallydesign stock them in red but im not all that fussed. Thanks for the photo Monty, can't wait to get my set on, hopefully for the NEC.
CJ101KT
Postby Enright » Sun 26.10.2008, 17:58
I'm sure we've had this discussion before but for the life of me I can't remember the answer:
Do the grooves in the outside surfaces of the disc have to face a particular way?
Postby bobbrown » Sun 26.10.2008, 18:18
There are two schools of thought on this one but I do not think it is critical which way round they go just a case of "horses for courses"
It is only critical when you have directional vane discs
Pacific Blue N/A
Postby RayD » Sun 26.10.2008, 19:52
Enright wrote:I'm sure we've had this discussion before but for the life of me I can't remember the answer:
Was it this one Neil.
Postby Enright » Sun 26.10.2008, 20:00
Yes it was. However at a quick glance that seems to answer the question about vanes rather than grooves.
Makes me wonder what the two schools of thought are.
Postby RayD » Sun 26.10.2008, 22:03
The underwater logic applies to both Neil,
I think if you were making them for the very first time you’d probably go for the grooves radiating outwards and backwards. It's not to say you couldnt find a reason for doing it differently.
Postby bobbrown » Mon 27.10.2008, 00:25
Schools of thought
One view is that grooves running such that dust and dirt is expelled from the disc and also for increased bite.
EBC view point
other view having the slots the “wrong way around” helped to decrease noise and does not throw brake dust onto the wheels as badly.
But if you have directional vane discs they must be fitted as per picture with referance to the vanes NOT the grooves
Pacific Blue N/A
Postby rickl » Wed 12.11.2008, 19:15
hello everyones. how do i purchase this kit in america?
rickl
Postby bobbrown » Wed 12.11.2008, 19:29
rickl wrote:hello everyones. how do i purchase this kit in america?
You can purchase the calipers in the USA and the discs should be available over there but will need modified to a 4 bolt pattern which is reasonably easy and can supply instructions(uses the original disc and a tool I can supply as a drilling jig).
The hardware should be easy to obtain over there.
The brackets I can supply from here
Pacific Blue N/A
Postby ailwyn » Wed 12.11.2008, 21:11
Bob,
Assuming there's not likely to be a limit on supplies, can you please put me down for one set of your Hi-Spec fronts - brackets calipers discs etc, I'll order the second at a later (more affluent) date. (I might order both sets of calipers though if a big enough discount can be had from Hi-Spec).
16" S2 Wheels.
Ailwyn
PS I like the sound of the template for the bolt pattern, can I please order one of those too?
Postby rickl » Thu 13.11.2008, 04:16
thx is there a part list i am misdsing
rickl
Postby bobbrown » Thu 13.11.2008, 12:48
Wilwood Dynapro/Midlite parts list
1. Wilwood Dynapro/Midlite calipers
Option (A) 2 x 120-7328 Piston size1.50" 38.1 mm Disc thickness 1.00" – 25.4 mm
Option (B) 2 x 120-7377 Piston size1.50" 35.1 mm Disc thickness 1.00" – 25.4 mm
2. Subaru Impreza front discs
(A) 2 x 16” rim 294mm x 24mm re drilled to a 4 bolt pattern.
(B) 2 x 15” rim 275mm x 24mm re-machined to fit and re drilled to a 4 bolt pattern.
3. 2 x Caliper mounting bracket (adjust for dim size)
4. 2 x Stainless steel M10 x 1.0 banjo bolts (short)
5. 4 x M10 copper washers for above
6. 4 x 3/8” UNC x 2” cap screws min 10.9 (caliper to bracket)
7. 4 x 3/8” Schnorr Safety Washers
8. 4 x 1/2” Schnorr Safety Washers
9. 2 x M6 x 20 counter sunk keep screws
10. 2 x spigot rings
11. Disc drilling jig optional (needs original disc and idealy access to a pillar drill capable of drilling 1/2")
Note: Either size of caliper will work the 7377 maintains the closest to the original front to rear bias but if considering upgrading the rear then the 7328 is the one to go for.
The calipers can be changed to the Hi-spec product and the only parts that change are the brackets and the caliper to bracket cap screws (M10 x 50)
Pacific Blue N/A
Postby bobbrown » Thu 13.11.2008, 23:38
Looks like the Wilwood calipers have gone up in price by some £20.00 each this is probably due to the exchange rate changes which makes the Hi-spec option more favorable.
When I started this there was a over £133.00 price differential but this has been eroded down to £86.00 but I can probably get this lower with the group buy for Hi-spec front and rear calipers.
I will ask the question of Hi-spec tomorrow.
Pacific Blue N/A
Postby bobbrown » Wed 19.11.2008, 15:50
The group buy of Hi-spec calipers has the price at £140.00 per caliper £280 the pair.
This is a good price and puts them on very close par with Wilwood calipers all be it the Wilwood is a good caliper as it is forged and then machined where as the Hi-spec is just billet machined (not as strong as forged)
Pacific Blue N/A
Postby tigerdog » Thu 20.11.2008, 21:54
At the current exchange rate, the Hi-Spec prices quoted here are less expensive than Wilwood's US street price (ignoring duty, etc.)
Postby Elanlover » Thu 20.11.2008, 22:15
tigerdog wrote:At the current exchange rate, the Hi-Spec prices quoted here are less expensive than Wilwood's US street price (ignoring duty, etc.)
One would think that a discount from a Wilwood reseller would also be possible with this type of volume. Still, they'd be close though :smt023
Postby bobbrown » Thu 20.11.2008, 22:36
Thats great for you guys over that side of the pond as even the "A" pillar seals are now cheaper.
It must be like getting a 20% discount, thats assuming the lotus dealers over there do a direct translation in price, or just take the price and add their profit on to it.
Pacific Blue N/A
