scottswatches wrote:I'ved just ordered two new 3/35 nova valves that i will modify to fit my original spring into, which make them 3/15's. Hopefully they will be here this weekend so i can spend my birthday under the car getting it back on the road. I will report the success/failure story here first.
scottswatches wrote:the internals of the valve were anodised purple, which didn't look like factory spec to us!
ashm wrote:scottswatches wrote:the internals of the valve were anodised purple, which didn't look like factory spec to us!
I remember thinking it was a bit odd when I was changing the brake lines on my old car and I noticed bits of the prop valves were anodised purple! They may have been this way from day one, strangely.
A quick run to my friendly MOT centre and I was getting 310 on the fronts and about 80 on the rear, with the handbrake at just over 100. Importantly, everything was balanced.
Success!
We took the spring out of the old unit and put it in a 3/45 new valve sourced from Vauxhall and rebuilt it and bled the brakes using RichyP's Gunson EeziBleed kit (now on my shopping list!). A quick run to my friendly MOT centre and I was getting 310 on the fronts and about 80 on the rear, with the handbrake at just over 100. Importantly, everything was balanced.
saska wrote:ashm wrote:scottswatches wrote:the internals of the valve were anodised purple, which didn't look like factory spec to us!
I agree -- Mark's article on rebuilding them shows a pink/purple piston too
ScottA quick run to my friendly MOT centre and I was getting 310 on the fronts and about 80 on the rear, with the handbrake at just over 100. Importantly, everything was balanced.
These figures look fine for front/rear balance -- nice job!
When you get a chance can you please measure the single valve body seal from your old valve. ID OD and thickness. I've already got the o-ring dimensions.
Also was there any problem getting the spring out of either valve?
The springs came out easily - in fact the whole job was pretty straightforward. Here are a couple of pic's to demonstrate the differences. I'll get you the body seal dims soon but i can't find my verniers and a ruler just isn't going to be accurate.
bobbrown wrote:It is important to note the spring dimension for the 3/15 valve are NOT the same as those for the 2/15 valve.
saska wrote:I don't understand why this would be so; the spring seats look identical and they're both 15 bar and the photos Scott posted look diameter-wise the same but thicker wire diameter/fewer coils on the 3/45. Still, I'll take your word for it.
bobbrown wrote:The 2/15 and the 3/15 valves are 15bar due to the different springs hence a 3/45 valve has a stronger spring.
Jackonicko wrote:
I'm puzzled at all the figures
