Problems with the FFS Hi Spec Rear Calipers ?
Re: Problems with Hi Spec Rear Callipers ?
Postby Monty » Mon 06.09.2010, 08:41
ailwyn wrote:Rather than getting in touch separately would it be a better idea to try and get exchanges done for those that want it as one group?
I don't mind doing the organisation, time permitting.
My thoughts on the next steps are:
1. Find out how many sets of calipers we are talking about
2. Get the dimensions of the replacement caliper (or an alternative of similar style/size) to establish if anything needs changing from the original kit, if so what.
At the moment i have no issue with mine but if there`s a problem with them leaking and that there not producing this caliper no more then i want them replaced and they should be free to exchange :twisted: Just hope they produce the new ones using the same mounting holes etc. :roll:
Ailwyn, Thanks for putting yourself forward in trying to get this resolved.
Post up here if you have calipers that you want exchanged
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
Postby MPx » Mon 06.09.2010, 09:45
Monty wrote:At the moment i have no issue with mine but if there`s a problem with them leaking and that there not producing this caliper no more then i want them replaced and they should be free to exchange :twisted: Just hope they produce the new ones using the same mounting holes etc. :roll:
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (Silver)
4. MPx (Gold)
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby saska » Mon 06.09.2010, 09:55
ailwyn wrote:Rather than getting in touch separately would it be a better idea to try and get exchanges done for those that want it as one group?{/quote]
I agree. Think it might be good if we included rear disk size/wheel size so HiSpec should be able to calculate any difference(s) between old & new calipers
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
4. saska (black, 256mm vented, 16"BBS, std H/B cables)
Thanks also ailwyn
Tony
adw (at) saska.co.uk
saska
Postby ailwyn » Mon 06.09.2010, 14:11
Tony,
I think wheel clearance and mounting points will be the key issues with the replacement as we know that the original caliper fitted and we would want something similar it's trying to get Hi-Spec to point out the differences so that we can identify what changes (if any) need to be made to the kit.
The worst case scenario I would have thought is new mounting brackets and new HB cables.
Hopefully the change to the caliper is an internal one and not a body re-design.... I'd have thought if Hi-Spec have a user base in the kit-car world then they'd be reluctant to force their customers to re-design the brake mountings etc if/when a replacement is needed.
Ray,
Can you please PM or Email the contact details to me?
Ailwyn
Postby RayD » Mon 06.09.2010, 14:31
ailwyn wrote:... I'd have thought if Hi-Spec have a user base in the kit-car world then they'd be reluctant to force their customers to re-design the brake mountings etc if/when a replacement is needed.
It's the impression I got from speaking to them ... there may also have been a mention of separate pads for the handbrake.
Ailwyn you have a PM/email
Postby Dico » Mon 06.09.2010, 17:30
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
5- Dico (silver, 256mm vented, 16" BBS, Bobs H/B cables)
Cheers Ailwyn :-)
Postby RichardK » Mon 06.09.2010, 18:34
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
6. Richard (Red, 256mm vented, 16" BBS, Bobs H/B cables)
Mine are sitting in a box in Cape Town - I will not be back until mid December.....probably about how long SlowSpec will take to get this sorted!!
RichardK
Postby MPx » Mon 06.09.2010, 18:43
I seem to have been lost in the crossfire so I'll put myself back in :o
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
7. MPx (Gold, 256mm grooved, 16" BBS, Bobs H/B cables)
Mike - MPx
86 Turbo Esprit
MPx
Postby saska » Mon 06.09.2010, 19:36
ailwyn wrote:I think wheel clearance and mounting points will be the key issues with the replacement as we know that the original caliper fitted and we would want something similar it's trying to get Hi-Spec to point out the differences so that we can identify what changes (if any) need to be made to the kit.
All of the SVA Handbrake calipers appear to be lug mount rather than the perpendicular through-the-caliper bolt mount we have. See HERE
All of the Ford & VW lugs are 90mm apart and the Billet is 140mm -- note they do a +20 VW (for a bigger disc) so it appears there is some flexibility in how they make the lug mount portion of the caliper. If everyone who wants to exchange calipers is on 256mm discs then it may make Hispec's job easier.
If the lug mount can be the correct distance apart and made for the correct size disc, then the only problem is the mount inboard/outboard offset from centre of caliper to center of disc. If the caliper centre is too far outboard it can be spaced, if too far inboard then we have a problem. I had a look on Wayback Machine for the dimensions of our present calipers but while they had much of hispec's web site they didn't have our calipers.
I agree we may need mounting bracket and H/B cables but I'm also concerned about the angle of approach of the H/B cable. Current calipers are almost vertical whereas the SVA appears to work from the side.
Think the Billet SVAs use a separate piston/pad for the H/B and also take different main pads to our Hispecs: they list Mintex MDB535 for the SVA whereas my rear pads are Mintex MDB1890.
Don't much care about paying for the bits as I'd just like a safe, reliable solution that is still 70/30 proportional with the fronts.
Tony
saska
Postby Gazza » Tue 07.09.2010, 11:57
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
8. Gazza (Red, 256mm Drilled, 16" BBS, Bobs H/B Cables) small leak already and not done 1000 miles.
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Avonvilla » Tue 07.09.2010, 14:16
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
9. Avonvilla (Black, 256mm Grooved, 16" BBS, std H/B cables(i think!))
Avonvilla
Postby whippit » Tue 07.09.2010, 22:14
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
10. whippit ( red , 256mm vented, 16" BBS, std H/B cables)
whippit
Postby paulwatkins » Thu 09.09.2010, 20:41
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
11. Paulwatkins (gold)
paulwatkins
Postby router » Fri 10.09.2010, 20:35
My rears are useless or shall I say the handbrake is useless the cars failed the MOT on effort my rears have already been back to Hispec once and they have come back with new seals, I asked them to check the handbrake as it was stiff to pull and they have come back the same.
The handbrake is too stiff for the wife to pull therefore I think its dangerous. I have since removed the rears and gone back to the old calipers and the cars passed the MOT straight away. If we can get working replacements id be well happy these havent even coverd 1000 miles, id say it was a waste of money....
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
12. Router (red)
router
Postby whippit » Sat 11.09.2010, 16:03
i had to help my hand brake through its mot with a little pressure on the foot brake ,
not good i know but as ide spent £1200 on the brake upgrade and was going to a show the next day in the car, there was no way it was failing on the rears,
the last straw was when i parked it on the drive, three clicks on the leaver , my left arm looks like popeyes, looked out of the window a couple of hours later,
the bloody cars parked its self across the road, strange thing no body beeped there horn or knocked on the door, must have thought its normal for a lotus to block the road
whippit
Postby Alan_C » Sun 12.09.2010, 12:59
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
12. Router (red)
13. Alan C (red)
Alan_C
Postby G UK » Fri 17.09.2010, 19:18
Still not fitted mine yet and had this thread pointed out to me at the last couple of meets. If the problem is as bad as is being reported I either want a fit for purpose straight replacement or refund. I do NOT want to fork out for new adapters and cables as this is all down to Hi-Specs poor design.
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
12. Router (red)
13. Alan C (red)
14. G UK (Gold)
https://gridcoin.ddns.net
G UK
Postby ailwyn » Mon 20.09.2010, 17:04
Sorry guys I've not been able to do anything with this yet, just changed jobs and hopefully things will settle down soon.
G,
The only thing you'll get refunded from Hi-Spec is the cost of the calipers as this is not a Hi-Spec kit.
I don't have any issue with the rest of the parts.... just a shame that the calipers are not just ornamental :(
I think we need to see what alternatives there are with the least additional cost as even with the refund from Hi-Spec I'd still be a fair wad of cash lighter.
A.
Postby whippit » Sun 26.09.2010, 00:31
just to keep this thread upto date,
rang hi-spec fri about time limits on the rear caliper , there looking at about a month for the re design,
looks like its going to be a piggy back handbrake mechanism, just machanical, not a hydro -machanical
the bloke i spoke to said it bolts to the main body of the caliper,
we dont have to get new mounts made, but the handbrake cables are no good,
the o/e cables have a ball on the end, but hispec have designed the new mechanism to take a clevis,
plus the adapter bob made to take are cable wont fit the new one,
over all it looks like its going to be a pain in the arse to get are cables to fit the new caliper,
not sure this is heading in the right direction to resolve a shite hand brake,
having to ether get new cables made or get new adapters made is going to cost.
whippit
Postby alexg » Sun 26.09.2010, 21:41
Hi, not been on for a while as busy with work and impending wedding..
I have had my rear calipers fail as well, sent them back to Hi-Spec and they rebuilt them and provided me with instructions that say you can't apply the handbrake with the foot brake on??? I am now expceptionally careful when using the car and find myself constantly checking that the brakes work as I have now lost confidence that they will be there when approaching junctions etc. This detracts gretly from the driving experience as you can imagine, I would be very grateful of any solution as, before the failure and now, the new brakes have transformed the car. I just have to have the confidence that they will always work, so added myself to the list.
1. Ailwyn (Gold)
2. Ailwyn (Black)
3. Monty (silver)
12. Router (red)
13. Alan C (red)
14. G UK (Gold)
15. alexg (black)
alexg
