Alternate willwood brake upgrade with dust seals
Re: Alternate willwood brake upgrade with dust seals
Postby bobbrown » Thu 13.11.2008, 12:48
Wilwood Dynapro/Midlite parts list
1. Wilwood Dynapro/Midlite calipers
Option (A) 2 x 120-7328 Piston size1.50" 38.1 mm Disc thickness 1.00" – 25.4 mm
Option (B) 2 x 120-7377 Piston size1.50" 35.1 mm Disc thickness 1.00" – 25.4 mm
2. Subaru Impreza front discs
(A) 2 x 16” rim 294mm x 24mm re drilled to a 4 bolt pattern.
(B) 2 x 15” rim 275mm x 24mm re-machined to fit and re drilled to a 4 bolt pattern.
3. 2 x Caliper mounting bracket (adjust for dim size)
4. 2 x Stainless steel M10 x 1.0 banjo bolts (short)
5. 4 x M10 copper washers for above
6. 4 x 3/8” UNC x 2” cap screws min 10.9 (caliper to bracket)
7. 4 x 3/8” Schnorr Safety Washers
8. 4 x 1/2” Schnorr Safety Washers
9. 2 x M6 x 20 counter sunk keep screws
10. 2 x spigot rings
11. Disc drilling jig optional (needs original disc and idealy access to a pillar drill capable of drilling 1/2")
Note: Either size of caliper will work the 7377 maintains the closest to the original front to rear bias but if considering upgrading the rear then the 7328 is the one to go for.
The calipers can be changed to the Hi-spec product and the only parts that change are the brackets and the caliper to bracket cap screws (M10 x 50)
Pacific Blue N/A
Postby bobbrown » Thu 13.11.2008, 23:38
Looks like the Wilwood calipers have gone up in price by some £20.00 each this is probably due to the exchange rate changes which makes the Hi-spec option more favorable.
When I started this there was a over £133.00 price differential but this has been eroded down to £86.00 but I can probably get this lower with the group buy for Hi-spec front and rear calipers.
I will ask the question of Hi-spec tomorrow.
Pacific Blue N/A
Postby bobbrown » Wed 19.11.2008, 15:50
The group buy of Hi-spec calipers has the price at £140.00 per caliper £280 the pair.
This is a good price and puts them on very close par with Wilwood calipers all be it the Wilwood is a good caliper as it is forged and then machined where as the Hi-spec is just billet machined (not as strong as forged)
Pacific Blue N/A
Postby tigerdog » Thu 20.11.2008, 21:54
At the current exchange rate, the Hi-Spec prices quoted here are less expensive than Wilwood's US street price (ignoring duty, etc.)
Postby Elanlover » Thu 20.11.2008, 22:15
tigerdog wrote:At the current exchange rate, the Hi-Spec prices quoted here are less expensive than Wilwood's US street price (ignoring duty, etc.)
One would think that a discount from a Wilwood reseller would also be possible with this type of volume. Still, they'd be close though :smt023
Postby bobbrown » Thu 20.11.2008, 22:36
Thats great for you guys over that side of the pond as even the "A" pillar seals are now cheaper.
It must be like getting a 20% discount, thats assuming the lotus dealers over there do a direct translation in price, or just take the price and add their profit on to it.
Pacific Blue N/A
Postby CJ101KT » Thu 27.11.2008, 22:30
Thanks for all the help with this kit Bob .... they have bedded in real well and they are soooo much better than the stocks lol.
Here are a few photos from the NEC , sorry about the lighting we did as good as we could over the weekend with photos but it was packed to the brim and im sure several of you came along for a chat. CJ
CJ101KT
Postby bobbrown » Thu 27.11.2008, 23:07
Now I can see the caliper
Pacific Blue N/A
Postby GeoffSmith » Thu 27.11.2008, 23:13
You blind bugger! :-D
Postby bobbrown » Thu 27.11.2008, 23:23
dogs at the vets and the white stick has broken
Pacific Blue N/A
Postby mnemonix » Fri 09.01.2009, 13:29
Sorry for being a bit thick, but I've been confused about the Wilwood brake upgrade since I started reading about it,
and Bobs name is on so many brake upgrade threads it doesn't help.
Bob's listed the components required for several options of Wilwood upgrade for both 15" and 16" wheels.
Are these just shopping lists for the parts we can acquire elsewhere or is he providing complete kits ?
Are all the parts available elsewhere ? A little voice is telling me that the BRACKETS are custom parts...
Does Bob provide these ? Are they the same or available for all Wilwood upgrades for both 15" & 16" wheels ?
As I've said in another thread, I'm currently upgrading my pads and discs for now, partly because of the cost,
partly on recommendation from GST and partly because I was plain confused about the details of availability,
group buys and everything else about a full Wilwood upgrade for my 15" wheels, but I'd like to be prepared for
that "told-you-so" moment where I go the whole hog on an upgrade.
Thanks,
Chris.
mnemonix
Postby GeoffSmith » Fri 09.01.2009, 13:58
See Bob's shopping list earlier in this thread!
Postby bobbrown » Fri 09.01.2009, 14:56
There are basically 3 Wilwood options the two originals http://wikilec.9600.org/index.php/Brake ... es#Wilwood which use calipers without dust seals and the one I developed with dust seals
The brackets are a custom part as they are made to fit either 15" rims or 16" rims, discs are modified from a 5 stud pattern to a 4 stud pattern (something Hi Spec also do with some of their upgrades) and the 15" disc has a small amount machined out of the center to clear the hub swivel mounting brackets.
Calipers, cap screws, banjo bolts, pads are all available as standard items from suppliers.
I can supply as little or as much as you like.
It should be noted that when I did this the calipers were cheaper than they are now and Rally Design only seem to like giving discounts if you order 4 calipers at a time no idea why. The cost is not far off the cost of the Hi Spec conversions now I have sorted out a good price with them but not sure if they will repeat the price but I am sure I can get close.
My only comment about Hi-spec v Wilwood is the Wilwood is a better made caliper being forged and only two piece as apposed to a billet machined item and in three pieces but both seem to do the job OK
Pacific Blue N/A
Postby mnemonix » Fri 09.01.2009, 16:08
Thanks Bob,
all is clear now, and when the time comes I know I can fit a Wilwood 15" upgrade kit with brackets and as much or little else as I want direct from you.
Chris.
mnemonix
Postby lotos » Sun 01.03.2009, 06:45
bobbrown wrote:
rickl wrote:hello everyones. how do i purchase this kit in america?
You can purchase the calipers in the USA and the discs should be available over there but will need modified to a 4 bolt pattern which is reasonably easy and can supply instructions(uses the original disc and a tool I can supply as a drilling jig).
The hardware should be easy to obtain over there.
The brackets I can supply from here
Uh oh - I'm not seeing these Wilwood calipers for sale online anywhere any longer... (They used to be on Jegs, Summit, and a handful of others, as well as ebay) Were they discontinued or replaced by new part numbers? Weird...
Bob - have you sent any kits to the US yet? Perhaps we could get a list together and you could ship over a few brackets / hardware kits at once to save on shipping cost? I know last time we chatted shipping was over $100 (although that was with more than brackets).
lotos
Postby bobbrown » Sun 01.03.2009, 10:18
The calipers as far as I am aware are available, with the Summit site use WIL-120-7328 and WIL-120-7377 as the part numbers and a number of other sites still list them ( http://store.revolutionbrake.com/wilwoo ... liper.html ).
They are more expensive than the Hi-Spec are here at present due to the exchange rate, Rally design price = £320.00 list inc vat and even if I buy 4 they still come in at £273.00 which is almost the same price as the Hi-specs.
In the USA the cheapest I have seen is $249.00 each which still makes them more expensive than I can get the Hi-spec calipers for here and ship them to the USA (pair Hi-spec calipers $471.00 including shipping).
I have one Hi Spec kit going to US probably in the next week or two and the total price came in at $820.00 (price may vary due to exchange rate) that was a complete kit shipped; Discs, calipers, brackets, hardware, pads, etc.
I have another rather custom Hi-spec setup due to go to Canada once Hi-spec has completed the rear calipers.
As for the Wilwood setup I can produce the bells and brackets for the early setups as well as the Dynapro but have yet to work out a cost for the early setups and sort out the drawings probably in the order of $350.00 including shipping.
The problem with shipping is the cost appears the same for anything up to 10Kg, then up to 25Kg and up to 70Kg and the figures look like this 10kg = $60.00 25kg = $110.00 70kg = $300.00.
So putting a list together and shipping them all at the same time is not a problem but would prefer for someone that side of the pond to organise.
Pacific Blue N/A
Postby lotos » Mon 06.04.2009, 22:19
Bob - what's your cost these days on calipers? I can't find a penny less than $500 for the Wilwoods you recommended. Any deals to be had? Should we possibly put together a group buy thread for the USA? What are your thoughts. I'm happy to receive the big box, sort into individual packages, ship, etc., once things get here.
lotos
Postby Monty » Mon 06.04.2009, 23:06
IIRC Bob gets them from Rally Design there £139.50 each (+ vat for the UK) thats around $205, i`m supprised you can`t get them for less in the USA since it Wilwoods are based in there :?
Postby bobbrown » Mon 06.04.2009, 23:52
I have searched for a lower cost in the US but I can not get below $249 which I do not understand as over here as Monty said they are the equivalent $205.42. even if you add in shipping they are cheaper here ($60.00)
I can get Hi-spec calipers for $206.00 (including our VAT) and I recently did a complete kit for a US owner and it came to $850.00 that was discs, Hi-spec calipers, brackets etc less hoses but including shipping.
The VAT element is a bit problematical Ok if you ship direct no VAT but adding them to a parcel here adds very little to the overall shipping costs. Sort of save on one hand and pay with the other.
Pacific Blue N/A
Postby Doug » Tue 07.04.2009, 00:41
Randy, you can call wilwood themselves if needed; since you have the part number I'm sure they will tell you that any of their distributors can get the part--find your favorite distributor and order . . .
