I am sorry, but she lacks important BBK specs (to keep things on-topic)
Simon_P wrote:have you got a smiley thing for that?GeoffSmith wrote:HJ2 wrote:Dapinky Fine, the Forum nanny
Shush you. You and your none-popularist voting nation.
...dapinky wrote:Henk-Jan.....
.... I know what the intention was - (and even it hadn't been that, I would have accepted it from you, as you have been here long enough, and contributed enough, to make such comments)
rip wrote:
Insults to strangers can become banter between friends.
TWAT.
TWAT.
Ha ha. Very clever Dave
dapinky wrote:You say that a Prop Valve is a 'band aid' but then state that you use different .cf pads to adjust bias - wow!...... at least a prop valve will retain a far more calculable operation over a range of conditions, whilst different pads will work differently even as they are being used....
lotusflasherman wrote:Steve A wrote::roll: If he doesn't respect the cars we drive or the people that drive them, then there's not really a place for him on our forum.
The statement "A bias valve on a production car is typically a sign of someone in the engineering department not picking the right parts, discovering the error too late, and scrambling to fix that problem too close to the production date." is written by somebody who either doesn't understand the basics of engineering, or is an internet troll... Your choice, matey.![]()
Bit fed up with 'Isuzu good, Lotus bad' mentality, particularly when expressed with such ignorance about weight transfer and brake balance, but it's been in every post he's made...
Soare these ...BRAKE-PROPORTIONING-VALVE-Isuzu
Come on Mr Pink where are you
isuzuowner wrote:The level of your ignorance. Or your desire to show off your ignorance.
alan e wrote:
Come on Mr Pick where are you
isuzuowner wrote:dapinky wrote:You say that a Prop Valve is a 'band aid' but then state that you use different .cf pads to adjust bias - wow!...... at least a prop valve will retain a far more calculable operation over a range of conditions, whilst different pads will work differently even as they are being used....
That's why they make pads in different brake coefficients.
That's why people who want to adjust their braking balance commonly change pads to a different cf on one end or the other.
Having the same pad coefficient for the front and back ignores the fact that the front brakes typically operate 200-300 degrees higher than the rear brakes anyway, shifting the cf accordingly.
HJ2 wrote:isuzuowner wrote:The level of your ignorance. Or your desire to show off your ignorance.
You are now talking about your own set of soft skills and somehow mismatched isuzuowner with flickerman (whoever that is), right?
It is better to substitute 'your' with 'my' in this context. my2cents
GeoffSmith wrote:Permanent ban. Goodbye and thanks for all the fish.
