lotos wrote:Thanks for the info! Looks like after buying rotors and pads, we're talking about ~ $750, plus $100 for brake lines. If my memory serves, you said that the Hi-Spec calipers use a standard connection, the Wilwoods require re-tapping, right? My overall plan is to powdercoat the new calipers (and the OEM rear calipers) yellow before installation, so the color choices don't matter to me.
Arrgggg. Don't know which to choose
To check sliding pin operation, all you need to do is remove the pads. The caliper should be able to slide in and out just by moving it with your hand. If it doesn't move at all or takes considerable effort then your sliding pins need greased/replaced (along with the seals.ratman wrote:Ciao,
thanks for your help! I suppose that it is necessary to disassemble completely the caliper for the sliding pins check and it shouldn't be possible to check them in another easier way...
