Gareth, i assume that as these are a custom design, then the bushes do not have to be exactly the same size as original?
If this is correct, then it is only the inner sleeve size which is critical (to fit the current bolt), and the shore (hardness) rating of the material.
The outer diameter isn't so important as presumably the bush holding tube on the wishbone can be made to fit whatever we can get hold of??
Is this all correct? Are there any physical size restrictions which could make life difficult when fitting etc?
Having asked loads of questions, I will point you in the direction of
Chris Wittor who is the UK main dealer of Superflex.
He is a really nice bloke to deal with, and a proper car enthusiast to boot (he has a Dolomite, so can't be all bad!!!)
In the past i have had dealings with him and found him to be extremely helpful.
I don't want to sabotage your efforts and go to him until you have answered the above points on what we need. Then if there is a bit of flexibility (no pun intended) on what we can get away with, dimension wise, he is probably the man to speak to.
EDIT:-
He lists a hell of a lot of 'universal' sizes, but can also custom make any other size you may want/need - (subject to a 100 of minimum order) if there isn't one to fit!
He is also amenable to discount pricing (As a Dolomite club member i get 15% off a £50 order, but i have also managed to negotiate substantial bulk order discounts in the past).
What the hell, whilst were at it, how about going the whole hog and seeing what else will fit an Elan - perhaps getting a 'full' kit together??
(I'm trying not to talk myself into a job here
