16" Wilwood bolts
16" Wilwood bolts
Postby RichyP » Wed 16.01.2008, 00:43
Car's just failed its MOT - all four disks need replacing :(
Time to do the Wilwood upgrade i've been putting off for over a year now however I'm stuck on the bolts issue.
Read all the posts on the subject, checked out Fast Fix direct but confusion still reigns! mainly to do with grade and de-embrittlement as mentioned by ESM - is 12.9 too brittle as that's all Fast fix seem to offer
Does anyone who has done this upgrade have spares that i could purchase? (pretty please!) or point me to somewhere where I don't have to buy 100 bolts to use just 4!!!
also Rally design have to order the hat to disk bolts as specified, from the US - so to save time I'm looking at other options of 5/16th UNF thread bolts - options include 1/2" or 3/4" length with or without nuts and normal or low head!!! too much to worry about and i'm not sure where space is an issue. Any Ideas?
never thought bolts would make my head spin this much!!
Cheers. Rich
RichyP
Postby GeoffSmith » Wed 16.01.2008, 08:26
Richy, Al was looking for bolts for the 15" Wilwoods - I don't know if he managed to source them though.
Postby theelanman » Wed 16.01.2008, 13:36
4NoCaliper to Bracket Bolts Metric M10x1.5 thread x 30mm long (with 1.2mm thk washer)
4No Bracket to Hub Bolts Metric M12x1.50mm thread x 35mm long (with 1.6mm thk washer)
get the wilwood bolt sets too......theyre good and less hassle
I got sets for every one last time round and gave 3 sets to everyone
(I had to order 100 of each)....but I cant find the name of the supplier...
what you need to do is coordinate a group buy.....I found the only way to get the correct bolts was to buy bulk :(
Postby theelanman » Wed 16.01.2008, 13:38
oh yes forgot...10.9 is what you want NOT 12.9...they suffer from fatigue if theyre 12.9
Postby theelanman » Wed 16.01.2008, 13:41
the M10 X 30mm 1.5 thread grade 10.9 here:
http://www.fastfixdirect.co.uk/code/nav ... ctID=25478
I'll keep looking for the others
Postby theelanman » Wed 16.01.2008, 13:43
http://www.bapp.co.uk
try these guys for the M12 fixing
Postby RichyP » Wed 16.01.2008, 15:15
Thanks for the speedy replys Geoff and Gareth!
I can't get the Fast fix link to work and the one in the original posting seems to lead to a product not available anymore!! typical!
was rather hoping that there might still be some left over from the original group buy - asked around at donny last year but no joy!!
I gather that it is possible to re-use the M12's with additional washers - these are the ones with the non standard thread and probably the most difficult to get hold of.
most of the Rally design staff are at the NEC for the autosport show and the guy I spoke to couldn't give me a delivery time for the hat /rotor bolts - since other parts seem to take weeks I thought i'd look at other options - he offered bolts that are 1" long but I figured this is too long?
I followed the 15" kit bolts that Alan ESM got - I think he may have got the 12.9 grade from Hawk fasteners then had them de-embrittled?? presumably to give a more favorable shear stress. Obviously I'm keen to get the 10.9 - but trying to cover all bases to get the bits as soon as possible - the car is dying being left outside for long periods with no use!!!!
As safety is paramount I just want to make sure I'm doing it right! This is the problem with being a mechanical engineer - a little bit of knowledge can scare the c*@p out of you!!!
Cheers. Rich
RichyP
Postby ab2cv » Wed 16.01.2008, 19:04
Rich, I will need the same bolts as you for my own wilwood kit (when I eventually get round to fitting it) so let me know when and where you get yours from (or if it helps the price buying in bulk, get me some at the same time)
Alan ;-)
Yellow Esprit GT3
ab2cv
Postby paulrwebster » Wed 16.01.2008, 20:11
Rich
When I ordered my disks from Rally Design they just sent me the hat to disk bolts that they "normally supply". I think that they are a bit longer but they fit OK.
For the big bolts, I did the padding out with washers trick, again it works fine.
Paul Webster
paulrwebster
Postby paulrwebster » Wed 16.01.2008, 21:04
I have pulled out my Rally Design receipt
It reads:
1 S1 Rotor to bell bolt/nuts/washers £13
I think that the part number S1 doesn't mean a lot, but I am sure they know what they supply. They were a bit long, but fit easily under the S2 wheels. They supply nuts with them (probably why they were long) but these are not necessary.
Paul Webster
paulrwebster
Postby RichyP » Thu 17.01.2008, 02:06
Thanks Paul
I just wanted to check the longer hat/rotor bolts would clear everything! does your post mean that you didn't use the nuts - just locktite? and that they are threaded from inboard to outboard?
So they're sorted and the M12's seem ok reusing the old ones - just leaves the M10's which should be the easiest to get! but 100 at 5p each is still a lot of dollar! will phone fast fix and see what they can offer - Bapp looks like having huge minimum orders but have handy charts showing tensile strength and hardness for the different grades on the web site
This bolt issue is the reason i've had the hats and brackets for 18 months and not fitted them!!
Alan - I had you in mind when I started this - by the looks of it i'm going to have too many bolts and i figured you wouldn't have got any further than me!!!
got all the parts for the rears so hopefully no problems there.......
RichyP
Postby paulrwebster » Thu 17.01.2008, 09:22
Richy,
I used Loctite and inserted them outside in. I shoved the nuts on as well just because I had them.
paulrwebster
Postby paulrwebster » Thu 17.01.2008, 13:16
I have some of the M10 X 30 bolts. PM your address to me and I will send you some.
Paul
paulrwebster
Postby RichyP » Thu 17.01.2008, 13:39
Cheers Paul - that's fantastic news! will send pm shortly...
Thats the best picture yet - was wandering which way the disk went on the hat!!
If you know the supplier it might be worth a mention on this thread to save future upgraders the insanity I suffered reading all the posts then cross referencing with the 15" threads just to make sure i hadn't missed anything!!! :bonk: (interesting that 12.9 grade seems ok for the 15" ???)
Rich
RichyP
Postby GeoffSmith » Thu 17.01.2008, 14:07
There are some write ups and pictures on the Wiki.
Postby RichyP » Thu 17.01.2008, 15:12
Read it all Geoff.... several times!! cheers anyway!!
will try to get some more photos at different angles to add to the write up.
I don't imagine it'll be too difficult - just not having all the bits together makes it difficult to anticipate where clearance will be an issue hense my apprehension - I'm in Edinburgh, had to abandon the car in birmingham at parents house so i'll have a very tight window to fix all the brakes and get the MOT. Ha - why do cars always need fixing when its cold outside??
RichyP
Postby GeoffSmith » Thu 17.01.2008, 20:07
Was it useful Richy? If there's anything that needs changing, don't forget that you are all empowered (I wish I hadn't said that, I hate HRbollockspeak).
Postby RichyP » Thu 17.01.2008, 20:49
Yep it's all useful Geoff. I do feel empowered but all the info seems to be there!!
Paul - got you're PM thanks for your help :D
Rich
RichyP
Postby nitroman » Sun 20.01.2008, 05:37
Richy, this info may help you.
Also, Geoff, you may deem this worthy of the Wiki page pertaining to 16" Wilwoods. The 15" Wilwood Wiki already lists the pertinent parts required, whilst the information below is missing from the 16" Wilwood Wiki.
1) 16 hat to rotor bolts (5/16"-24 x 3/4")
2) four M12 x 35mm bolts, 1.5 pitch, to attach the caliper brackets to the car.
3) four M10 x 30mm bolts, 1.5 pitch, to attach the Wilwood calipers to (Brian's) caliper brackets.
NOTE: The M12 x 35mm bolts are fine pitch and can be found at...
http://www.boltdepot.com/product.aspx?c ... 11&cd=1309
Wilwood parts needed...
Code: Select all
Qty  Part #
2    120-6816   Caliper
1    15Q-6824K  Pads
2    160-5844   Rotors
2    230-0150   Bolt kit (8pk)
nitroman
Postby GeoffSmith » Sun 20.01.2008, 18:40
Thanks for that Matt. I must get around to completing the write up!
