Foo wrote:You mean like pulsing against your foot under braking?
Monty wrote:The Ref wrote:Foo wrote:You mean like pulsing against your foot under braking?
yes Foo that is what I mean. I think it may be air in the system.
Billy
If it's Pulsing then that sounds like warped disc to me
The Ref wrote:Monty wrote:The Ref wrote:Foo wrote:You mean like pulsing against your foot under braking?
Billy
only 700 miles on a new set of discs/pads the n/s one was warped on the inside edge. had it skimmed so ok for now. I will keep a eye on the mileage to see if it happens again. if so they will be going back. thanks for your help one and all.
Billy
Monty wrote:The Ref wrote:Monty wrote:The Ref wrote:Foo wrote:You mean like pulsing against your foot under braking?
Billy
Billy
If ony one disc was warped then you must have a brake caliper problem ie sticking sliding pins. So more than likely this will happen again
Monty wrote:If it's Pulsing then that sounds like warped disc to me
Elanlover wrote:I used to call it "warping" too but this is a little factoid I learned last year
bobbrown wrote:That looks more like a material flaw than any thing else.
If the crack was heat related I would expect to see a lot of hair line cracks as per pic
Users browsing this forum: AhrefsBot and 8 guests
