Alternate willwood brake upgrade with dust seals
Postby bobbrown » Thu 07.08.2008, 14:39
I have looked at the issues people have had with the Wilwood conversion and have looked at an alternate caliper.
It should be possible to fit the Billet DynaPro Caliper radial mount which I believe has dust seals.
I have also found a one piece disc that with a few minor modifications will fit so you have two options using the same caliper
15” standard OZ rims
277mm diameter x 24mm one piece disc
16” standard rims
295mm diameter x 24mm one piece disc
Cost is reasonable discs can be purchased for around the £100.00 the pair grooved, calipers are £280.82 + brackets £80.00
Makes the kit around £420.00 for either 15” or 16” you may have to add in a little extra for the hoses but if you have stainless hoses fitted it should be possible to change the end to suit the 1/8 NPT on the Wilwood calipers
It would also be possible to use the Hi-spec calipers in place of the Wilwood ones and should only require a different caliper bracket.
Also in both cases going from 15” to 16” rims would only require a change of bracket
I have drawn the arrangement up (autocad) and although tight it does fit
Just trying to get a feel for those that might be interested in this as an upgrade route
Postby ailwyn » Thu 07.08.2008, 14:57
I might be interested in swapping the calipers on my 16" wilwood for ones with dust seals but don't want to go to the expense of replacing the whole lot again... if I were going to do that I'd probably hop on the hi-spec bandwagon.
Others that have previously gone the Wilwood route might be interested in doing the same.
Postby bobbrown » Thu 07.08.2008, 15:47
That is possible, but the original setup was on a thin non directional 20.8mm disc
My proposal is to use a thicker 24mm directional disc which is better
The Hi-spec caliper could also be used on this setup as it is very similar to the Wilwood one
Postby ailwyn » Thu 07.08.2008, 15:59
bobbrown wrote:That is possible, but the original setup was on a thin non directional 20.8mm disc
Bob,
A lot of the technicalities went past me, but as I understood it they were definately directional discs... an arrow stamped on them to show the direction of rotation and following the instructions posted by Brian on here.
Not sure about the thickness, maybe someone can confirm :?
Postby bobbrown » Thu 07.08.2008, 16:18
opps! I should hve said curve vane as the original Wilwood was straight vane which makes them directional
Postby F1 LOTUS » Thu 07.08.2008, 17:30
The only disc I could fit in the space without spacing the wheel out or modifying the caliper is .81" thick - people sourced these from various places and various spec's (grooved, drilled etc etc). I have a precise digitized model of the 15" wheel that Kuching kindly supplied when I worked on that installation. If you don't already have one you'll be welcome to use this to check your design before making chips? :)
F1 LOTUS
Postby bobbrown » Fri 08.08.2008, 16:45
Hi
Was the use of the 0.81" disc more driven by availability as apposed to what would actually fit?
Hi-spec supply a kit for the 15” wheel (275 dia x 25 mm) but I am not sure that the wheel is not spaced to give clearance no doubt someone will advise.
I know that a thicker disk is preferable over a thin one as it has a greater capacity to absorb and get rid of the heat.
The Wilwood calipers that I have selected are by no means ideal as they are meant for 1” (25.4mm) discs and again this is a compromise, as for the Hi-spec caliper they should be ideal as there is a 24mm option in their Billet 4 caliper.
F1 LOTUS if you have a precise digitized model of the 15" wheel that Kuching kindly supplied I would be grateful of it
I have the hub etc drawn up and can see where the problems are likely to be and the wheel is the most critical area.
I also have a front hub assembly kindly loaned by Phil so I can see if it will all fit on the bench rather than the car.
Postby F1 LOTUS » Fri 08.08.2008, 20:14
The .81" was pretty much all I could squeeze in there - to the extent that I needed to use low-head hat-to-disc bolts! The Wilwood dimensional details are a joke, so some allowance needed to be made for that during packaging. Perhaps a 1-piece disc will give some wriggle room? I'll lookout the model for you and whizz it across. :)
F1 LOTUS
Postby bobbrown » Wed 20.08.2008, 00:41
I have tried the 293mm disc I have in mind on the front hub assembly and they fit a treat.
The brake caliper mounts sits very nicely inside the disc and I have a small clearance between the disc and the lower ball joint so this is just about as far inboard you can mount a disc.
The caliper should fit inside the standard 60mm offset wheel so it is all looking very good at present.
Ok the Wilwood calipers are the expensive bit but they do have dust seals and stainless steel bridge pieces.
Re: Alternate willwood brake upgrade
Postby clan » Wed 20.08.2008, 15:42
bobbrown wrote:I have looked at the issues people have had with the Wilwood conversion and have looked at an alternate caliper.
16” standard rims
Cost is reasonable discs can be purchased for around the £100.00 the pair grooved, calipers are £280.82 + brackets £60.00
Bob, I'm watching this thread and the other Wilwood thread with interest. I'm not ready at the moment to upgrade my brakes but its second on my list for the near future. I will be looking for an upgrade to suit 15" OZ rims so if there is any other interest then I would purchase the brackets to suit if the project moves on.
1992 SE - Monaco White - 64,000 miles and climbing.
White Is The New Black.
clan
Postby bobbrown » Thu 21.08.2008, 12:37
Here are some pictures of the disc mounted on an Elan hub this shows the brake bracket sitting inside the disc
Postby bobbrown » Thu 21.08.2008, 12:38
and the clearance to lower ball joint + the overall view of the disc
Postby Monty » Thu 21.08.2008, 14:58
Bob,
Will the Billet DynaPro Caliper for the 16" kit fit inside the S2 wheel? Was just wondering as the spoke do curve in quite a bit :?
Postby bobbrown » Thu 21.08.2008, 15:07
I have got the cost of the calipers down to £99.50 each if ordered in blocks of 4 so this will effect the overall cost by some £47.00
I have worked out I can bring this kit in for £400.00 with plain discs or £420.00 with grooved discs.
You can pay a lot more for these discs anything up to £200 + the pair
Postby bobbrown » Thu 21.08.2008, 15:39
Monty wrote:Bob,
If my dimensions are correct and the drawing of the inside dimensions of a S2 wheel are correct then yes but it is very tight at a the closes point it is 1.7mm from the wheel but I have tried to be as accurate as possible.
The Proof of the pudding is to machine the bracket and try a wheel.
I have access to a wheel so that is not too much of a problem.
The setup is so so close to what Hi-spec offer but the Wilwood caliper's shape does allow a slightly larger disc,I think Hi-spec are using the same disc machined down on the OD to 285mm.
I have drawn the arrangment up with a Hi-spec caliper and it does not quite fit and you have to reduce the diameter to get it to fit hence no doubt why they have gone for a 285mm disc diameter as it reduces the height of the caliper by some 4mm which is then enough to clear the wheel
Postby bobbrown » Fri 22.08.2008, 12:55
It would appear that the a similar setup can be applied to the 15" wheel but with a smaller disc
In this case the same source can suppy the disc at 276mm diameter, will require a little machine to clear the brake caliper bracket but all other things being equal then this should fit OK along with a dust sealed Wilwood Billet DynaPro Caliper, as per the 16" wheel brake upgrade.
This comes out very close to the Hi-spec upgrade in terms of disc size etc theirs is 275mm and the calipers from disc face to out side of caliper are very similar
Hispec is 49.5 mm and the Wilwood DynaPro is 49mm.
Postby Monty » Fri 22.08.2008, 13:49
Bob,
Isn`t the Dynapro a two pot caliper?
http://www.rallydesign.co.uk/product_in ... ts_id=8310
Postby bobbrown » Fri 22.08.2008, 14:03
No
It is what Rally design have down as their Midlite caliper for some reason when I spoke to them about the cost they said it was to stop confusion with the Dynalite Pro.
http://www.rallydesign.co.uk/product_in ... ts_id=8317
Wilwood list it as the Billet DynaPro Caliper
http://www.wilwood.com/Products/001-Cal ... /index.asp
Postby Monty » Fri 22.08.2008, 19:19
bobbrown wrote:No
Oh yeah that won`t cause confusion lol :roll: god help anyone who`s going to order calipers and pads :lol:
Postby bobbrown » Sun 07.09.2008, 11:40
It looks like the clearances on the 16" S2 wheel are fine (see pic)
The 15" OZ rim is a little closer and it is just the cap screws that hold the two halves of the caliper together that are the problem they are just a little bit too tall (2mm) but that should be easily overcome by fitting low head capscrews or machining 2mm off the existing ones.
Will add some pictures of the 15" setup complete on the hub once the brackets are completed
Pacific Blue N/A
