Raft bushes (rear)
Raft bushes (rear)
Postby Gordon » Sun 19.10.2008, 22:00
Has anyone ever succeded in changing the rear lower raft bushes with the rafts still on the car?
Gordon
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Re: Raft bushes (rear)
Postby Gordon » Tue 21.10.2008, 11:02
Is the (unusual) deathly silence an indication;
a) it can't be done
b) it's that easy that I'm stupid for asking - It's B - read the HOW-TO
or
c) no one's ever tried?
Gordon
2005 Vectra C....
Gordon
Postby dapinky » Tue 21.10.2008, 13:51
I'm a subscriber to 'option C' - never tried, sorry I can't help :?
Postby Freelander » Tue 21.10.2008, 14:21
Hi Gordon,
I have also looked at this and decided it would simple (easier) to remove, rebush and replace. My reasoning related to access, brake pipes, getting the old ones out and the need for general derusting etc.
Let us know how you get on!
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
Postby Gordon » Wed 21.01.2009, 16:25
Still struggling with this one...
I've got the old bushes out (cut the rubber out, then collapsed the outer sleave).
How much force am I looking at to press the new ones in - any ideas?
Gordon.
2005 Vectra C....
Gordon
Postby Gordon » Tue 27.01.2009, 19:55
OK,
Anyone interested / care how I did this? (they're both in, and I didnt take the rafts off....)
I took some pictures ;)
Gordon
2005 Vectra C....
Gordon
Postby niall » Tue 27.01.2009, 23:44
Good man. Well done. Now can we see the pictures?
niall
Postby GeoffSmith » Wed 28.01.2009, 15:37
:chair:
USB ElanScan interfaces - £60 incl. P&P.
Postby Gordon » Wed 28.01.2009, 23:31
Here's a quick write-up.
I'm not sure on how to submit it to the Wiki - if it's worthy, can someone stick it in for me?
Raft_Rear_Bush_HOWTO.pdf
Ta.
2005 Vectra C....
Gordon
Postby dapinky » Thu 29.01.2009, 13:58
Gordon,
Now I can see how simple it is, I might have a go myself (these are the only major bushes on the red elan elan which are still not in Poly!).
As always, I'm sure there was much head scratching and trial & error along the way before ending up with such a 'simple' system.
And i certainly don't mean to sound like I think you should have got the answer quicker - I know how awkward it is to do many jobs on cars, not just elans, before coming up with that moment of epiphany when it all seems so easy.
Postby RichardK » Fri 30.01.2009, 11:46
What an elegant and straightforward solution......I would have had the raft off for sure!
great stuff Gordon, well done!
NEW ORLEANS - YELLOW 91 FED. TLC Required.
RichardK
Postby RayD » Fri 30.01.2009, 22:05
Great job Gordon, and thanks for reducing the size of the PDF file for us dial up people (from 5 to 1MB)
Postby Bern » Tue 30.01.2018, 21:14
I'm thinking of changing the raft bushes, the PDF doesn't exist any more. Everybody says what a simple solution it is, but can anybody let me know what it is?
Cheers,
Bern.
'90 Elan SE
'05 Mazda MX5
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
'80ish Kubota B5100E
Bern
Postby Brit-Car-Nut » Tue 30.01.2018, 22:42
Use www.lotusm100.com/manuals
The forward bush is C100C6006F and the rear is either C100C6006F or E100C6001F if after VIN R 6001 ( I know the Fed Car uses to latter # as does the S2.
They are both obsolete from Lotus SJs has both numbers listed as available.
Lotus Manuals
Postby Bern » Thu 01.02.2018, 11:42
Brilliant, thanks, though it was the PDF posted by Gordon that I was after, it sounds like he had a nice way of doing it without removing the raft. I've not really looked at how the raft bolts to the car (though I did look at it in your hosted manuals), I'll take a look at the weekend.
I started thinking about the raft bushes about 2 hours after I had placed an order with SJ!! I'm still only thinking about it at the moment, it'll probably be a few months before I get round to it.
Cheers,
Bern.
'90 Elan SE
'05 Mazda MX5
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
Bern
Postby Brit-Car-Nut » Thu 01.02.2018, 14:18
I have several front suspensions disassembled and I don't see any way to replace the lower bushings without removing the RAFT.
Sometimes, cutting corners ends up being more work than doing it right.
Lotus Manuals
Postby dapinky » Thu 01.02.2018, 14:58
As long as the bolts arn't seized, removal of the raft isn't a hard job - and as already said, removing and replacing the bushes in situ isn't anything like an easy option.
When I have done them in the past, I am fortunate enough to have a spare pair of rafts - so I can replace all bushes in slow time, then just swap the rafts over. Sometimes, the one coming off will need a bit of work to remove seized bolts (which I cut off to remove the raft), so if it is time-critical you may have problems getting it all done.
Postby Gordon » Thu 01.02.2018, 17:22
I'm trying to locate the howto - or at least the pictures - will update in due course....
I've found the pictures - I'll knock up the HowTo Again tomorrow (Y)
It's amazing how time ticks by - I'd not just lost the PDF, I'd completely forgotten ever doing the job!
2005 Vectra C....
Gordon
Postby Gordon » Fri 02.02.2018, 12:36
As promised:
Hope this helps!
Please distribute/host so this is not lost again, but please retain credits in the file.
Gordon
#2 - revised to include some pictures of the failed bushes.
2005 Vectra C....
Gordon
Postby Giniw » Fri 02.02.2018, 13:31
Thanks! :-)
Giniw
