Braided Stainless hoses with stainless fittings
Postby bobbrown » Thu 28.05.2009, 11:33
While doing all the brake upgrades I have another source for these hoses and at a lower price.
These are all stainless steel fittings and the company uses nothing but stainless.
These are supplied with the front center mount unlike the Goodridge ones which are supplied with "P" clips which are a pain to fix any where.
I can also get these for the Wilwood upgrades if anyones has gone rusty
The cost should come out at around the £65.00 ish mark including VAT and delivery.
For those in the brake upgrade group buy MK2 then I will adjust the price accordingly and will sort out when they are sent out how much to send back.
Pacific Blue N/A
Re: Braided Stainless hoses with stainless fittings
Postby HJ2 » Thu 28.05.2009, 13:10
That's a good price for a complete SS set :D
So £65.00-ish for a complete set for an S2 Elan, Stock brakes ?
Postby bobbrown » Thu 28.05.2009, 13:24
Yep
Stock brakes or Hi-spec upgrade only thing that changes is the banjo bolts as the threads are different.
Pacific Blue N/A
Postby HJ2 » Thu 28.05.2009, 13:40
Let's hope that my cambeltchange works out nice and cheap!
(so i have a few euro's left to spend on hoses :-)
Postby bobbrown » Thu 28.05.2009, 14:54
Getting rid of the ish
Can confirm the price is £62.00 inc VAT delivered UK can get them shipped worldwide but price will depend on shipping costs but likley to be £70.00 delivered.
Also available coloured 18 colours available
Pacific Blue N/A
Postby max and andy » Thu 28.05.2009, 15:19
Even purple Bob? Max
max and andy
Postby bobbrown » Thu 28.05.2009, 15:55
yep and at no extra cost
Pacific Blue N/A
Postby Don.Hasi » Thu 28.05.2009, 23:51
bobbrown wrote:These are supplied with the front center mount unlike the Goodridge ones which are supplied with "P" clips which are a pain to fix any where.
Hi Bob,
I couldn´t find a proper translation for it :( What is different to the goodridge ones for example? Thanks for explaining in advance.
Greets
Don.Hasi
Postby Elanlover » Fri 29.05.2009, 14:05
bobbrown wrote:yep and at no extra cost
Bob, when you put my package together for shipping which set of brake lines am I getting -the "original" ones or these? 'Cause black would look mighty nice :-D
Postby texas2201 » Fri 29.05.2009, 14:23
HI Bob
What length are these as I am fitting Wilwoods to one of my Excels and the current braided hoses are too small to reach the calipers. Also do you do the elbows to convert the calipers?
cheers
Martin
PS I didnt get those seats so I am still looking
Postby bobbrown » Fri 29.05.2009, 17:54
martin you have an email
Pacific Blue N/A
Postby bobbrown » Fri 29.05.2009, 18:00
Greets
On the original front hose the hose is clipped to the upper wishbone.
The goodridge hoses do not have provision for the hose to be clipped in as per the original.
Goodridge supply a P clip for each cable, not sure where you are supposed to put is but it is a pain.
These hoses come with the center mount and follow the same route as the originals.
If I can sort the camera out (faulty card) I will post some pictures of the two side by side.
Pacific Blue N/A
Postby inkitin » Fri 29.05.2009, 18:20
Can I buy these on their own for stock SE brakes?
Roland
91 SE Calypso Red
inkitin
Postby bobbrown » Fri 29.05.2009, 18:29
available for the standard brakes or upgrades just need to know what they are for as the banjo bolts are different and front hoses on some Willwood kits
Pacific Blue N/A
Postby inkitin » Fri 29.05.2009, 18:39
Thanks Bob
You have PM.
Roland
91 SE Calypso Red
inkitin
Postby mvf906 » Mon 01.06.2009, 19:00
Hi bob, if your making a list, I'd like a red set to go with my new Hi-spec kit :D
me in my head, shifting & drifting, mechanical music, adrenaline surge
mvf906
Postby bobbrown » Mon 01.06.2009, 23:32
Ok will add them to your parts on the brake upgrade.
Hoses in red
Pacific Blue N/A
Postby mvf906 » Tue 02.06.2009, 09:11
thanks bob, funds will be transfered this morning :mrgreen:
mvf906
Postby Don.Hasi » Fri 05.06.2009, 16:07
bobbrown wrote:
Greets
ah, thanks for the explanation, Bob :)
The center mount seems to be the same like ours :) As the brakelines are unique to the elan and have the same layout, I would guess in genral, they are the same…
The only difference there could be, are the cones of the fittings… Does anyone know, which ones are on the sides?
And the last question: we have a kind of "nose" at the end of the lines. The new ones doesn´t have any… I think they are only for comfortable fastening (?) Does this any other matter if they are absent?
Don.Hasi
Postby bobbrown » Fri 05.06.2009, 20:07
Your hose may have the banjo location on the end of the banjo but I have not seen one on my car.
The fittings on the other end from the caliper which I assume is what you are talking about when you say cones are correct for our fixed pipe work
Pacific Blue N/A
