MoT brake stuff - What does it mean?
Postby lotusm100elan » Sun 10.10.2010, 00:25
I was looking at an Elan, and copied down some mumbo jumbo from the MoT
Axle 1 (745 kg)
bind 21 kgf n/s, 9 kgf o/s
brake force 273 kgf n/s L 9% L 280 kgf o/s total 553 kgf
Axle 2 (420 kg)
bind 10 kgf n/s, 9 kgf o/s
brake force 66 kgf n/s S 26% S 66 kgf o/s total 132 kgf
brake force (parking) 141 kgf n/s L L 128 kgf o/s
Service pass value 50%, test value 59% pass 685 kgf
Parking pass value 16%, test value 23% pass 269 kgf
Is this good, bad, or indifferent.
They was red brakes on the front, like. Hispec.
lotusm100elan
Re: MoT brake stuff - What does it mean?
Postby lotusm100elan » Sun 10.10.2010, 21:07
There must be some brake guru who knows what all this means and weather it's good bad or indiffrent for an Elan with Hispec fronts and (I guess) standard back.
Please can someone educate me, like?
lotusm100elan
Postby theelanman » Sun 10.10.2010, 21:50
look alreet 2 me.....
it passed :)
Postby AnonImouse » Sun 10.10.2010, 21:55
Red ones don't squeak.
The only good cat is a dead one.
AnonImouse
Postby theelanman » Sun 10.10.2010, 22:16
AnonImouse wrote:Red ones don't squeak.
lol......
white one do tho......apparently :-D
http://www.youtube.com/watch?v=saY10AWXLIY
Postby bobbrown » Sun 10.10.2010, 23:05
Axle 1 (745 kg) weight on front axle
bind 21 kgf n/s, 9 kgf o/s Amount of drag on the front wheels not only brake related but also includes transmission
brake force 273 kgf n/s L 9% L 280 kgf o/s total 553 kgf amount of force on each wheel when the brakes were applied plus the total and is dependant on a number if factors including tyres and the state of the equipment the test was carried out on to name but two
Axle 2 (420 kg) Weight on rear axle
bind 10 kgf n/s, 9 kgf o/s As above but in our case no transmission may be just a little bit of brake drag
brake force 66 kgf n/s S 26% S 66 kgf o/s total 132 kgf amount of force on each wheel when the brakes were applied plus the total this figure may seem low when you compare it to the parking brake force but that is due to the line pressure being controled by the proportioning valves.
brake force (parking) 141 kgf n/s L L 128 kgf o/s parking brake figures
Service pass value 50%, test value 59% pass 685 kgf the pass value is the same across the board and the test value is obtained by taking the two totals front and read and dividing by the weight x 100 and expressed as a percentage.
Parking pass value 16%, test value 23% pass 269 kgf Similar to the above but only using the parking brake readings e.g. 269 divided by (745+420) x 100 = 23%
Over all it looks fine hope that helps.
Pacific Blue N/A
Postby theelanman » Sun 10.10.2010, 23:11
bobbrown wrote:it looks fine......hope that helps.
:-D wot i sed...... :-D
Bob, u'll have to come n work wiv me at Ferodo
Postby bobbrown » Sun 10.10.2010, 23:26
theelanman wrote:Bob, u'll have to come n work wiv me at Ferodo
Wot commute I think not and if I'm going to move it's back south, going back to my roots, back to the Isle of Wight.
Pacific Blue N/A
Postby theelanman » Sun 10.10.2010, 23:38
still got your passport then :)
Postby lotusm100elan » Mon 11.10.2010, 00:51
Thanks Robert Brown. So no shockers, like? That's good.
What sort of numbers might a stock set up get? Worse, right?
lotusm100elan
Postby Specky » Mon 11.10.2010, 07:06
Just Looked..
And unless I'm having a brain fart, tis highly possible it's early. Those figures fall right in the middle of stock set up.
I'll have a think today....
Postby lotusm100elan » Mon 11.10.2010, 10:28
I don't understand what you're saying, Specky. 'Early'?
But it sounds as if it's not what you'd expect for a car with Hispec breaks?
lotusm100elan
Postby Specky » Mon 11.10.2010, 11:27
Search the forum for standard MOT brake figures and you'll see what I mean.
The results appear to be just adverage for an Elan with standard brakes, terrible for an ultra modern car.
Hispecs are better brakes than standard, so if you're looking for an Elan I'd personally be cautious.
I'd be intrested in the AP results or another set of Hispecs.
Postby bobbrown » Mon 11.10.2010, 11:32
So do you have Hi Spec calipers or standard ones painted red?
It's easy to tell Hi-Spec calipers as they have Hi Spec Motorsport writen on the out board face.
Pacific Blue N/A
Postby lotusm100elan » Mon 11.10.2010, 11:40
These are definitely Hi Spec calipers. They're red and have Hi Spec in white on them.
Could it be that the fluid was low? I only had a quick look at the car and its paperwork.
lotusm100elan
Postby Enright » Mon 11.10.2010, 12:34
I wouldn't suggest posting the reg no, but it's highly likely to be someone who we know, so if you could just say what colour the car was and which garage you saw it at they may well stick their head above the parapet, then you could discuss the performance before and after the upgrade direct.
Postby lotusm100elan » Mon 11.10.2010, 13:03
It wasn't in a garage Enright and it ain't even for sale I don't think. It was an owner who I chatted to in John Lewis car park late night shopping one thursday I went over to his gaff cos he said I could drive it and go over it as much as I likes in daylight so I could sort of get used to what to look for and so I would know what I was looking at when I was looking at one that I might want to buy, he showed me how to look at the wishbones and where the VIN was and stuff gave me a load of printouts of some buyer guide thing from here and talked me through it, and let me go over his paperwork and lent me a pair of big files of articles from magazines and that.
lotusm100elan
Postby theelanman » Mon 11.10.2010, 14:53
where abouts are you......and did the messiah say anything else? will the greek inherit the earth? :)
if this car isn't yours & your not buying it...why the interest in the brake figures.....the next one you llok at will be completely different....and surely the owner knows....:)
;-D
Postby lotusm100elan » Mon 11.10.2010, 15:24
I hope that any car I will look at will have a MOT and the same brake figures (not the same, but in the same format), and I want to know whats right and whats not right and if it can be measured in actual numbers I want to be able to interpet what the numbers mean if you see what I mean and I can't find on the board anywhere what figures would be good and what would be bad. Specially as everyone goes on about how crap the standard brakes are, like, and how its worth getting one with Hispec brakes or AP brakes or Willwood brakes, but this one had the Hispec brakes yet the figures show they ain't working as good as they should.
As to the geezer who tried to help, well at least he tried to help and didn't rip the mickey out of me for what I don't know but am trying to find out. And if he's got a problem with his brakes I'd really like to be able to tell him that, returning the favour sort of thing.
I'm near High Wycombe and that's how come I was at John Lewis car park, like.
lotusm100elan
Postby Here Welsh Tree Rot » Mon 11.10.2010, 15:39
mae o'n siared trwy ei het.
Dwi a 'n fawr bloneg Cymraeg bastai bwytawr
Here Welsh Tree Rot
