I'm starting this as a seperate topic to keep it tidy!
This is for those that have the Hi Spec rear calipers and want to fit the longer levers.
If you want to discuss the levers then use this
topic but please not this one.
I have made up some longer levers and I am awaiting the test results from Ailwyn. SteveA and Monty, they should work better than the original one supplied by Hi Spec but the proof of the pudding..........
Assuming this design works then I need to know who wants them as there is a cost in this case £20.00 delivered.
You get two new longer levers, and two new longer brackets plus a a length of 5mm stud bar which will need to be cut to length if required.
The stud bar is to extend the link between the handbrake lever and the compensating link, in some cases it may not be required but is there just in case.
The new levers are in a similar style to the old ones all be it longer and the end where the cable fits is bent back to stop the cable comming out. Pic to follow.
List
1. Ailwyn test subject
2. SteveA test subject
3. Monty test subject
4.
5.
6.
