by alan e » Mon 17.06.2013, 20:32
Has anyone fitted the rear calipers for 15in wheels from PNM engineering if so are they any good, they say on there site that the calipers have a modern efficient hand brake mecanism.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
by Jeemy » Mon 17.06.2013, 20:37
I'm waiting to hear back from them now! I have always planned to fit these (although I will go for the 16" set if it works) and Peter is highly recommended by a few people.
Now it seems I don't have a choice as mine are binding and in the interests of aesthetics I'm going to fit new items rather than go second hand. Keep an eye out on the Group Buy section as I think I will be able to get the custom hubs built again pretty soon, and hope to take the 16" kit and make a bracket for it allowing for a slightly bigger rear disc. I know a few on here have them and are happy with them; I think its a case of no news is good news as we've all heard about the problems with the Hi-Specs which in fairness to HiSpec were never made to be compatible with the Elan from what they've said to me.
T: 0800 084 3084
M: 07391 295 146
Jeemy
by muley » Sat 22.06.2013, 17:48
I ordered mine over 2 months ago, when i get them and fit them I'll let you know..
by Rice crispy » Thu 27.06.2013, 22:03
Jim did you get them yet ? Or has anyone fitted them yet? My car passed its MOT yesterday but my mechanic says that the callipers are shot, did say last year that the sliders were seized so I've ordered a pair from PNM today £400 with pads and delivery
should be here this time next week for installation. He said that he had orders for a few sets that he was about to send but would get mine out asap.
Rice crispy
by muley » Fri 28.06.2013, 11:53
Not received yet. PNM have phoned to apologise for the delay (Peter's mother has died and Peter has had to go to France to sort things out
Rgds
by Rice crispy » Fri 28.06.2013, 15:07
Jim many thanks for the update, he did say he had some orders and would get mine out next week as my car is off the road
Rice crispy
by muley » Sat 29.06.2013, 07:38
Update : mine are being shipped Monday.
by Rice crispy » Sat 29.06.2013, 07:53
good news, mine are going straight to my mechanic friend who is going to fit them so will post when they are done.
Rice crispy
by cliff » Sat 29.06.2013, 19:24
alan e wrote:Has anyone fitted the rear calipers for 15in wheels from PNM engineering if so are they any good, they say on there site that the calipers have a modern efficient hand brake mecanism.
I fitted them in march and drove 900 miles with the novelty and pleasure of having modern feeling brakes and a handbrake that worked.
viewtopic.php?f=80&t=19040&start=80Easy to fit, although I had previously refurbished my rear hubs. Peter did mention that had he known of the Bob Brown (now Jeemy?) hubs, he could have incorporated bigger disks.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
by Rice crispy » Sat 29.06.2013, 19:42
cheers Cliff
Rice crispy
by Rice crispy » Fri 05.07.2013, 09:27
still waiting for mine were meant to be there earlier in the week, then yesterday, now monday
was hoping to use the car at the weekend as apparently its going to be hot.
Rice crispy
by muley » Fri 05.07.2013, 09:59
Well, mine arrived.. ..but they don't fit - currently working on a solution.
by Rice crispy » Fri 05.07.2013, 21:38
Jim why don't they fit ?
Rice crispy
by muley » Sat 06.07.2013, 15:04
They do not fit because I have non-standard hubs and discs fitted. I have a kit that came from someone called, er, Bob, I think
The caliper carrier has about 1mm clearance either side of the disc. So, because my non-standard hub/disc combination sits 1mm closer to the car than standard the carrier rubs the disc. Not good. I am working on a temporary fix.
Worth noting to anyone who is contemplating using the PNM kit.
Rgds
by cliff » Sat 06.07.2013, 16:15
Jim,
I have this kit fitted with Bob´s hubs. One issue I had was that the caliper slider bolts were 2mm too long and contacted the discs, a 2mm washer cured the problem.
I discussed this on the phone with Pete and sent a feedback email but had no reply to that.
You have PM
07 Alfa Spider 939
cliff
by muley » Sat 06.07.2013, 17:18
Clive
Thank you for the post and the PM. I've double-checked and the bolt isn't standing proud. I suspect PNM have provided a thicker washer.
If I space the disc away from the hub with a spacer, all is good. Not the perfect engineering solution. Alternatively I could get 1mm milled off the PNM bracket then it would be OK, but I'd loose the passivated surface.
Almost stumped TBH..
Regards, and thank you
by Rice crispy » Sat 06.07.2013, 18:13
So jim have you got standard hubs on yours?
Rice crispy
by Denny » Mon 08.07.2013, 08:18
Just for clarity; do they fit standard hubs with 15" or 16" wheels without modification?
Denny
by Rice crispy » Mon 08.07.2013, 09:21
Denny many thanks hope they will be at the garage today and didn't want a call to say there were problems. already missed a glorious weekend without the car
Rice crispy
