Corner weight Elan
Corner weight Elan
Postby m100sandra » Thu 08.05.2014, 17:16
I had the Elans Geo checked & adjusted Today, Just for interest the total weight was 1032.5
Front
345 -------- 346
Rear
162.5 -------- 179
Front 691 -- 66.9%
Rear 314.5 -- 33%
Gross 510.5 -- 49.4%
Total 1032.5
m100sandra
Re: Corner weight Elan
Postby Specky » Sun 11.05.2014, 01:46
What configuration did you have the car in? (Driver, passenger, fuel load, hood up or down etc)
Looking at the figures I'd say you have a couple of weight saving mods (even if unintentional), no driver, half a tank of gas...
Makes me wonder how the Fed Élan weighs in, and also their weight distribution. I've always thought slightly heavier, but a better weight distribution... But it's only my guess..
If my assumptions are correct... you've got the front weight distribution better than Lotus had, but I know nothing about setting a car up... And they're the daddies.
Postby m100sandra » Sun 11.05.2014, 10:17
No spare wheel. Hood up, tank just over half full, he did comment that it corner weighted good :?
m100sandra
Postby HIBUTK » Sun 09.08.2015, 02:33
Corner Weighted Fed Spec Elan with stock springs & shocks, Sparco seats, conv. top up, 16” Fed wheels, 88,000 miles, spare tire & tool kit in trunk, driver on left side weighing 180 plus or minus, fuel load un-noted; taken in September 2009.
Front Left Right
904 lbs 789
Front: 65.62%
Rear Left Right
422 465
Rear: 34.38%
Left: 51.4 %
Right: 48.6%
Total Weight : 2580 lb
HIBUTK
Postby lotusflasherman » Sun 09.08.2015, 12:58
HIBUTK wrote:Corner Weighted Fed Spec Elan with stock springs & shocks, Sparco seats, conv. top up, 16” Fed wheels, 88,000 miles, spare tire & tool kit in trunk, driver on left side weighing 180 plus or minus, fuel load un-noted; taken in September 2009.
Front Left Right
904 lbs 789
Front: 65.62%
Rear Left Right
422 465
Rear: 34.38%
Left: 51.4 %
Right: 48.6%
Interesting .. the OP didn't give units so I guess was in kg and my phone ap converts her figures to
Front 761 lbs 763 lbs
Rear 358 lbs 359 lbs
Totals 2276 lbs ....
(haven't a clue what "Gross 510.5 -- 49.4%" means..)
Having just fitted a blue hood I'd say they are not very heavy and the main weight is at the rear between the b pillars so hood up or down won't change f/r ratio much, if at all. Fuel in the tank probably much more significant.
