by par » Tue 03.01.2017, 20:59
Would be grateful if someone could advise on the correct type of brake pads to suit the 16" rear PNM conversion.
Going by the search results it seems the calipers are based on those fitted to the Golf MkIV, does that mean any pads for a Golf MkIV are suitable for the kit on the Elan and does the 15" & 16" kit use the same pads? The PNM website seems to list different part numbers for the pads in each of the kits.
par
by GeoffSmith » Tue 03.01.2017, 21:20
PNM fettle the Golf pads to suit the 15" and 16" setups.
- Kitty Fiddler
by par » Tue 03.01.2017, 23:21
Thanks Geoff, probably easiest just to buy direct from PNM then.
par
by Jamie N » Tue 03.01.2017, 23:46
par wrote:Thanks Geoff, probably easiest just to buy direct from PNM then.
Probably easiest doing to them what PNM do.... Grinder
Jamie N
- Seal God
by par » Wed 04.01.2017, 00:40
Jamie N wrote:Probably easiest doing to them what PNM do.... Grinder
Not a bad shout Jamie as I can use the old ones as patterns! Just ordered a set for £9 so not expensive if I make a mess of it.
par
by Scott J » Mon 09.01.2017, 19:54
Pads were almost new so you've been racking up the miles
PNM sell them as mentioned .
Scott J
- The prodigal son
by par » Mon 09.01.2017, 20:32
Not as many miles as I would have liked
I have new discs to be fitted as the current ones are quite pitted (probably from sitting around at SMS) and would rather fit new pads. I picked up a set of the Golf MKIV rear pads for under £10 with the Eurocarparts discount and cant see any difference, so maybe it is the 15" kit that the pads get fettled for!
par
by John_W » Mon 09.01.2017, 21:56
par wrote: so maybe it is the 15" kit that the pads get fettled for!
Yup.
- Heid-bummer
