by hocombewood » Fri 17.03.2017, 17:51
Hi All !
I havent been on this forum for several years. about 5 years ago I was following a thread on some alternate brake calipers and there was a bracket too which one of the members had made up for the handbrake. I bought the caliupers, to fit myself, but managed to free off the brakes, but finally now after the last two MOt I have to accept that I need new rear calipers. Id like to use these ones I bought in 2011 or so, but I cant find the thread now on here ? can anyone please point me to it. I seem to remember a meembers name like Aldrigas ? had designed the conversion, but I could be wrong, thanks for all help.
hocombewood
by Brit-Car-Nut » Fri 17.03.2017, 18:19
Lotus offers a corrected cable for the caliper with the odd lever: A100J6114S
They are £15.70 and you would have to replace the whole cable and re-adjust your hand brake lever, but probably easier than getting your lever(s) cut apart and the welding the old end on the new stub.
Algirdas no longer has any levers available.
by Saltire » Fri 17.03.2017, 18:29
The member might have been Algirdas.
And
this could be the thread in question.
However, I believe the preferred option these days is
the PNM Engineering one.Hope this helps.
1995 Elan S2, BRG
Mrs Saltire’s 2022 Mini Countryman Cooper S
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by hocombewood » Sun 19.03.2017, 17:44
Yes thats, it, thanks, does anyone have any drawings of the modified levers, I could get some made up at work.
here's hoping.
rgds
hocombewood
by hocombewood » Sun 19.03.2017, 19:33
Hi, I think I have had a memory wipe, I now recall I bought the dormal calipers and handbrake levers from algridas. but now on opening the boxes 8 years later, I need some other parts on the dorman calipers.
I have the bots in the photos and the bit I dont have i've highlighted in yellow from the dorman datasheet. does anyone know if I could still get these bits highlighted ?
thanks in advance to all who view this reply.
hocombewood
by hocombewood » Sun 19.03.2017, 19:46
I see the PNMkit is only £400 for new rear calipers, I think I have my solution. I'll call them tomorrow.
hocombewood
by Brit-Car-Nut » Sun 19.03.2017, 20:05
What you have highlighted are the brake pads and some retaining bits. That is a generic picture and you don't even use most of them. You should have all of the parts you need still on the car. Calipers rarely arrive with brake pads, but you can get them from your local DIY store or maybe someone can suggest an affordable source for you.
by dapinky » Sun 19.03.2017, 21:48
There are enough bits in your photo above - you just need brake pads (which are the same as the OE callipers).
- LEC Administrator
