REAR LOWER WISHBONE INNER BUSH SET (Poly)
Postby lotusrepair » Wed 29.03.2017, 04:46
I had a mixup and thought I had these on hand when the rear suspension was started. The car is apart and I need to get it back together quick. Taking up the lift and it is not my lift. Is there a local solution to matching these poly bushings for us in the USA?
lotusrepair
